69 RR flashers? How Many? #178455
12/29/08 09:08 PM
12/29/08 09:08 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
On a 69 RR is there just 1 flasher for the turn signals and emer. flasher are is there suppose to be 2? And if there is 2 where are they both located? TIA Ronnie in Okla.
Re: 69 RR flashers? How Many? [Re: okie] #178456
12/29/08 09:34 PM
12/29/08 09:34 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
There should be two.
Re: 69 RR flashers? How Many? [Re: sthemi] #178457
12/29/08 09:36 PM
12/29/08 09:36 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
One by the ashtray and another near the switch panel.
Re: 69 RR flashers? How Many? [Re: sthemi] #178458
12/29/08 10:55 PM
12/29/08 10:55 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Thanks! I had found the 1 by the ash tray but I couldn't find the other 1. I get out there in the morning and try to find the other 1. The wiring has been bad, someone had chopped and spliced all the harnesses up bad in this car but I'm about to get it straightened out. THANKS RONNIE
