Condensation under valve cover? #1784458
03/20/15 05:33 PM
03/20/15 05:33 PM
Northern California
lilcuda Offline OP
lilcuda  Offline OP
Northern California
Pulled a valve cover today to check the valve lash and found milky stuff inside the valve cover and on the rockers. Car has no PCV, just breather hoses that go to a remote breather/accumulator. It hasn't been driven in about a month. Oil on dipstick looks totally fine.
I'm assuming this is just condensation. Thoughts?
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Condensation under valve cover? [Re: lilcuda] #1784459
03/20/15 06:09 PM
03/20/15 06:09 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Yes, that's what it is. One cause is starting your engine and shutting it down before its warmed up usually takes a few times of doing this. Also storing your car in an area with high humidity with major temperature swings. Storing a car in a garage that sweats is not good.
Re: Condensation under valve cover? [Re: lilcuda] #1784460
03/20/15 06:17 PM
03/20/15 06:17 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
My girlfriend's Durango Looks the same way at the oil file location when I change her oil. You can also see clear condensation in droplet form. I really think it is just the oil and water vapor mixing and creating the mayo looking sludge.
Re: Condensation under valve cover? [Re: parksr5] #1784461
03/20/15 06:43 PM
03/20/15 06:43 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
You need to take cars like this out for a nice long drive to warm up the oil to burn off the condensation that is collecting in the oil.. Short trips that do not heat the OIL and allow it to burn off the water that collects in it from sitting create this.....
Re: Condensation under valve cover? [Re: minivan] #1784462
03/20/15 06:46 PM
03/20/15 06:46 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Funny thing, my girlfriend drives her Durango to and from work everyday which takes her 2.5 hours. I think the fill location on hers is just a great catch area for rising condensation and does not see the heat that the rest of the engine does.
Re: Condensation under valve cover? [Re: parksr5] #1784463
03/20/15 09:53 PM
03/20/15 09:53 PM
Dr Dave Offline
Dr Dave  Offline
Same problem on my 2000 Dakota, dealer changed out the oil filler cap and hasnt been a problem since. I believe it was a recall fix.
