Leaf spring problem on A-body #1784300
03/20/15 01:32 PM
03/20/15 01:32 PM
Louisiana
JL2 Offline OP
JL2  Offline OP
Louisiana
I'm needing wider wheels on my 68' Barracuda and need to move the leaf springs out of the way or deleted with another option. Any ideas on my options to use at least a 10" wheel?
Re: Leaf spring problem on A-body [Re: JL2] #1784301
03/20/15 01:45 PM
03/20/15 01:45 PM
MP had the box sheetmetal kit that you welded into a cutout in the front subframes. it might be NS1 tho I saw one for sale recently (here iirc) or find a good fabricator/welder locally.
Re: Leaf spring problem on A-body [Re: JL2] #1784302
03/20/15 01:46 PM
03/20/15 01:46 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Dr Diff makes a 1/2" spring relocation kit. That puts the outside edge of the spring inline with the inner wheel well lip. If you need to go wider then that, you'll have to move the springs in to the frame rails and mini tub the car.
