Re: replacement for gas tank sending unit hose
[Re: mopars4ever]
#1784168
03/20/15 03:41 PM
03/20/15 03:41 PM
RapidRobert
3/8" hard line I'm assuming? Go the other way & get a piece of 3/8" hose instead of 5/16" hose the wrap something around the 5/16 sender nipple to build it up a bit just not quite as high as the "flare" on the end then install the hose & clamp it with a hose clamp. It'll work fine on your suction side
[Re: mopars4ever]
#1784171
03/20/15 05:42 PM
03/20/15 05:42 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Yes there is a company that does, but they change a fortune, like $250, I had to google it to find them originally and don't currently have the link. Tim http://tristarrradiator.com/
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: mopars4ever]
#1784173
03/21/15 12:33 AM
03/21/15 12:33 AM
RapidRobert
Have your parts man cut you a snip of 5/16 and 3/8 regular cheap neoprene line & see what you can do with fitment as that'll tell ya which way to go when you get ready to buy the good hose. I took a plastic? vac cap nipple (ACE hardware calls em "screw protectors" & cut the closed end off & slid it on my 5/16" pump hard nipple then slid on & hose clamped a 3/8 neoprene hose. They are pennies & I forget if I used the green or yellow one. It was just the right thickness to get the hard nipple OD closer to the hose ID and was thin enough that the flare on the end of the hard nipple still had a larger OD than the OD of the rest of the shank of the hard nipple & gave a good seal with a hose clamp right behind it. Are the windings shot (no continuity) in your sender? plus you wanna go to 3/8". Not exactly your situation but with aftermarket senders being off the charts problematic I kept my working 5/16" sender & added a 3/8" bung in the bottom of the tank which was easy since I had a new Frankie Mitchell (God rest his soul) tank going in.
[Re: mopars4ever]
#1784175
03/21/15 12:52 AM
03/21/15 12:52 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
What year and body style are you working on? I've had 3/8 and 1/2 hardlines welded into a stock pickup along side the stock 5/16 pickups ![](/ubbthreads/images/graemlins/thumbs.gif) Anything is doable , as long as you can do it or your'e willing to pay someone else to do it for you ![](/ubbthreads/images/graemlins/scope.gif) I had a 3/8 hardline added into my stock 5/16 pickup on my 1969 Dart GTS, I also replaced the stock 5/16 fuel line to the front with a 1/2 aluminum line for drag racing that car years ago.I used a Moroso Y fuel block in the rear to go from the two inlet lines to the bigger 1/2 line going up front, worked good, lasted a long time ![](/ubbthreads/images/graemlins/boogie.gif) I sold that car and the new owner removed that pickup and bought one with a 3/8 pickup, I bought that car back several years later and he gave me that old pickup back also ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I can't remember now if that sender still worked when he remove it or not ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: mopars4ever]
#1784178
03/21/15 01:40 AM
03/21/15 01:40 AM
RapidRobert
You have in effect a 5/16 system. Yes the sender line needs to upgraded to 3/8 to have the flow potential of a full 3/8 line. When adding a different hard line thru the sending unit circular flat piece it (the flat piece) needs to be flanged or fittings on either side of the flat on the line for support
[Re: dogdays]
#1784180
03/23/15 02:00 PM
03/23/15 02:00 PM
RapidRobert
I believe that a 5/16" section in a 3/8" system will cause it to only be able to flow what the smaller (5/16) line section is capable of. I could be wrong on that tho
