What cam specs in your 500+" street Hemi?
#1783936
03/19/15 09:53 PM
03/19/15 09:53 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What cam specs are you running and how much do you drive it in the street? I will drive mine 95+% on the street.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: What cam specs in your 500+" street Hemi?
[Re: 65 Hemi]
#1783937
03/19/15 11:13 PM
03/19/15 11:13 PM
Just try and use a solid anytime you play with a Hemi Hyd's are like a governor in a real hemi
[Re: ]
#1783938
03/19/15 11:38 PM
03/19/15 11:38 PM
65 Hemi
San Diego CA
Yes, it currently has a solid roller but it is a race profile. This was a new motor for Don Bauries KOS old roadrunner. Unfortunately he passed before he got to use it. I got it from a guy that bought it from his estate sale. Muscle Motors has no specs on the build.
Doug
[Re: quickd100]
#1783940
03/20/15 12:12 AM
03/20/15 12:12 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Contact Chase Knight from Crane cams, he recommended a solid roller with pushrod oiling. Mine is 242@.050, .628 Lift, 112 lsa....but my 572 has only 9.5 to 1 compression. You need to give him all the information like carbs, head flows, compression, manifold, application, altitude, etc. I am planning on 99% street driving with my 4 speed and Dana 70 axle.... ![](/ubbthreads/images/graemlins/stirthepot.gif) so I know it will hold up....
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: quickd100]
#1783941
03/20/15 01:26 AM
03/20/15 01:26 AM
Posts: 12,422 Taxes & Virus's R-US, NY
Dragula
I have run a lot of cams over the years and I am again switching back to Bullet after my last Comp cam was ground on a chevy lobe design.... Here is the one in my 605, but bear in mind, I run a little higher ratio than stock so my valve lift will be a smidge higher at .680" at the valve. ![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/Scan10027_zps8d4f3b45.jpg) Here is my Comp cam I had in my 484...Was missing some mid range, and I noticed it right away. Now if you notice a not to the right where I spec'd a replacement Bullet cam, that is where I would start if you have a decent stall convertor. ![](http://i427.photobucket.com/albums/pp357/cudahalr/70HemiCuda/CamCard3_zpsc701ef2d.jpg)
[Re: 65 Hemi]
#1783943
03/20/15 10:36 AM
03/20/15 10:36 AM
Posts: 12,332 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Rich Nedbal spec'd the cam for my street 505". Solid roller .645/.638 246*/256*. Idles nice and pulls to 7,000.
Master, again and still
