Rod side clearance ?? #1783895
03/19/15 08:14 PM
03/19/15 08:14 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I am working with a 440 source RB 4.250 stroke crank and a set of Eagle 7.100 rods. The problem I am having is that the rods are two wide to fit the crank. The rods seem to be Mopar width and the crank pin is Chevrolet width. Has any one found this problem before?
T & K Performance
Re: Rod side clearance ?? [Re: ChevyTS] #1783896
03/19/15 09:14 PM
03/19/15 09:14 PM
I think they make a deal about it on their site like it is a good thing --perhaps for them if it makes you use their rods? I think you could work on the eagles and make it work--how much wider are they?
Re: Rod side clearance ?? [Re: ChevyTS] #1783897
03/19/15 09:26 PM
03/19/15 09:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have had to surface grind SB rods to fit the crank
on one of my engines... I should have gone back to
the crank company to have them do their job right..
he messed up and turned the crank to chevy diameter
but didnt do the width right.. on my last engine I did
the same thing but went back to him and he did the width..
on the SB I ground .013 off the inside of each rod
to fit with clearance
Re: Rod side clearance ?? [Re: MR_P_BODY] #1783898
03/19/15 09:45 PM
03/19/15 09:45 PM
They seem to be addressing the issue of Eagles on regular cranks having a mile of side room--supposed to be all kinds of oil Bogeymen bad things but I have NEVER seen any harm from tons more side room than we really need--"oh it bleeds off oil yadda yadda" I say maybe on yours but has never hurt any builds I had --Yes if you are taking a test >055 per pair is way wide but--does it hurt anything? I say no big deal but I do understand why they would want to correct this with the specs on their cranks and rods and make it more correct--I think yahoo Except--then when you go to use others rods you get --ehh..some grinding to do--all in the game of engine building me boys--these days with parts from all parts so to speak Nothing is a given or fits--Respect your engine builder--he is fighting this EVERY single day--
Never build an engine shop beside a liquor store--it is bad for the engine builders
Re: Rod side clearance ?? [Re: ] #1783899
03/19/15 10:08 PM
03/19/15 10:08 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
From memory I think the Eagle rods are 1.013 on the big end. The crank is 2.009 . I can get better numbers tonight. I have built many B/RB strokers before and I havent seen this yet. I wanted to get more input before I machine the rods to .995.
Re: Rod side clearance ?? [Re: ChevyTS] #1783900
03/19/15 10:32 PM
03/19/15 10:32 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Eagle rods are set up that way to fit Eagle cranks. Most any other aftermarket steel rod will fit the offshore cranks with the BBC journals. You could have them surface ground,or just get the right rods.
RIP Monte Smith
Re: Rod side clearance ?? [Re: CompWedgeEngines] #1783901
03/19/15 10:40 PM
03/19/15 10:40 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mopar rod big end width spec is 1.017", BB Chevy is .992"
Doug
Re: Rod side clearance ?? [Re: dvw] #1783902
03/19/15 10:43 PM
03/19/15 10:43 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Doug
Thanks Doug
Re: Rod side clearance ?? [Re: CompWedgeEngines] #1783903
03/19/15 10:45 PM
03/19/15 10:45 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
So that means that Eagle cranks use eagle rods. I see.
Re: Rod side clearance ?? [Re: ChevyTS] #1783904
03/19/15 10:51 PM
03/19/15 10:51 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I have been using mostly Scat products.
Re: Rod side clearance ?? [Re: ChevyTS] #1783905
03/20/15 09:55 AM
03/20/15 09:55 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Put an old bearing in the rod. Torque it, and chuck up on the inside if the big end in a lathe and turn it down. Easier, faster.
Re: Rod side clearance ?? [Re: dthemi] #1783906
03/20/15 01:49 PM
03/20/15 01:49 PM
Syracuse,NY
Syracuse,NY
Havent tried it that way yet..lol...
RIP Monte Smith
Re: Rod side clearance ?? [Re: CompWedgeEngines] #1783907
03/20/15 07:24 PM
03/20/15 07:24 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Update. The crank was 2.004 2.006. the rods were 2.007. I machined the rods to .9935 .994 I have .0014 ish side clearance
Re: Rod side clearance ?? [Re: ChevyTS] #1783908
03/21/15 09:52 AM
03/21/15 09:52 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have the same issue. Bb Chrysler alumium rod, bb chevy crank. How much side clearance should I cut for aluminum.
Re: Rod side clearance ?? [Re: ChevyTS] #1783909
03/21/15 12:15 PM
03/21/15 12:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Too tight imo..........
Re: Rod side clearance ?? [Re: Thumperdart] #1783910
03/21/15 12:28 PM
03/21/15 12:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
He has .008 clearance now.. thats even tight to me
(not the .001+ he shows)
Re: Rod side clearance ?? [Re: MR_P_BODY] #1783911
03/21/15 01:02 PM
03/21/15 01:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - .008" would make me nervous.
Boffin Emeritus
Re: Rod side clearance ?? [Re: MR_P_BODY] #1783912
03/21/15 01:28 PM
03/21/15 01:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Built a roundy round small chevy for a guy years ago and it had about .012 iirc and it ran awesome and faster than ever till it let go. The rods were burnt pretty badly and the oil full of metal. Mine are bet. .035 and .050 and have been for many years.
Re: Rod side clearance ?? [Re: ChevyTS] #1783913
03/22/15 12:48 AM
03/22/15 12:48 AM
Cab_Burge Online work
Cab_Burge  Online Work
Add another .010 and you should be good, that ain't a Chevy motor Way to loose on rod side clearances works good on Mopar stroker motors
Re: Rod side clearance ?? [Re: Cab_Burge] #1783914
03/22/15 12:57 AM
03/22/15 12:57 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Is this a new purchase from 440 source? If so they sent the wrong parts. Call them and get the right rods.
