Re: Interior floor pan color
[Re: 440mopar]
#1783458
03/19/15 12:39 PM
03/19/15 12:39 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Yep, body color....not a great job or great coverage but definitely body color, at least the cars I've looked at. Year? Model? Plant?
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1783459
03/19/15 02:20 PM
03/19/15 02:20 PM
Posts: 110 So. Illinois
bronze69
So. Illinois
Occasionally you would even get a totally different color floorpan due to the fact that the same spray gun was used for different colors. So, they would spray the floorpan first to get the previous color flushed out of the gun and lines. I have seen a green Cuda with a partially blue floorpan from the factory.
68 Gold Met. 383-4spd Roadrunner
69 T5 Hemi 4-spd Roadrunner
70 Limelight 440-6 Auto Superbird
[Re: 440mopar]
#1783460
03/19/15 04:14 PM
03/19/15 04:14 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The gray you saw would be the dip primer. I've seen cars with really good coverage and others maybe 50% covered. Really with the carpet installed, you won't see it, so I just use enough paint to seal the primer.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1783461
03/19/15 11:37 PM
03/19/15 11:37 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
I have a one owner car undergoing its first restoration. The interior floor pan is close to but not quite the exterior color, F5 Limelight Poly green.
The main thing is the paint on the floor is low gloss. F5 is glossy.
Since the console is specified as Bayou Green Metallic low gloss in the factory service manual, I put the console on the floor to see if that's the color. It does not seem to be that color or that paint either.
So I put the instrument panel on the floor to see if they match. Nada.
The exterior and the floor pan are both green, just not the same green. Since my upper and lower door frames are F8 Ivy Green Poly, maybe the floor is F8? Nope, F8 is glossy and the floor isn't.
What's on my floor can't be matched to any other color that's on the car. But almost.
I'll leave it to my painter to empty his gun on the floor with whatever green is in the gun.
The firewall in the engine compartment is definitely painted with exterior body color, except where the painter didn't bother to lower his gun for full coverage and there is no paint. The firewall on the interior is just painted the same as the floor but not very high and below the dip line. That gray dip primer looks flat gray to me, not semi-gloss.
This photo shows the trunk with F5 gloss hanging on the garage wall at upper left. The floor pan is close but not that color.
