727 deep pan extension #1783286
03/19/15 02:04 AM
03/19/15 02:04 AM
fresno ca
mikeysmopars Offline OP
fresno ca
Getting ready to change to a deeper trans pan and noticed the filter extension does not have an o ring like the one I took off. Is that gonna make any difference?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 727 deep pan extension [Re: mikeysmopars] #1783287
03/19/15 02:10 AM
03/19/15 02:10 AM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
So the one on the left is the one you are going to use ?.....
I would make-up a quick gasket. It could suck air if you don't use something to seal it.
Re: 727 deep pan extension [Re: mikeysmopars] #1783288
03/19/15 02:10 AM
03/19/15 02:10 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Good thing you're chucking that aluminum pan for the superior steel one!
Re: 727 deep pan extension [Re: J_BODY] #1783289
03/19/15 02:15 AM
03/19/15 02:15 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Good thing you're chucking that aluminum pan for the superior steel one! [/quo
Re: 727 deep pan extension [Re: BeEtLeJuIcE !] #1783290
03/19/15 02:17 AM
03/19/15 02:17 AM
fresno ca
fresno ca
Was just going to change oil n filter but had the cast on the shelf but don't want to take a chance on the trans losing prime. Probably why I got a good deal on it!
Probably stay with the steel.
Re: 727 deep pan extension [Re: mikeysmopars] #1783291
03/19/15 03:19 AM
03/19/15 03:19 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
hardly think that thing will lose prime using the spacer you have. Probably run it around the "add" line. My dad had one of those aluminum Summit pans on the Duster when I got it. Got one of the lucky ones that leaked, even with the reusable gasket. I swapped it out for a 47RH pan I had laying around. I do miss the drain plug, but could add one to the steel pan I suppose.
Re: 727 deep pan extension [Re: mikeysmopars] #1783292
03/19/15 08:16 AM
03/19/15 08:16 AM
new york usa
P
pattyboy 572 Offline
P
new york usa
Some used a gasket in earlier designs.....If u cant locate one ,i've made em....
http://www.kmjent.com/cart/images/P/MOR42080.jpg if u feel u want an o ring... http://www.summitracing.com/parts/der-14010/overview/
