How to unlock steering - 70 Cuda #1783111
03/18/15 09:04 PM
03/18/15 09:04 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I inherited a 70 Cuda 2 years ago. It sat in a barn for 30 years. Then it has been in my dads shop for 5 years. We took the drive shaft out to roll it. But the roll back guy put it on the rollback, and rolled it straight into the shop. Well my shop is done and it's time to bring it home. It's not like the steering column is locked, just like the sterring theft lock has it locked. We don't have any keys for it. The locksmith wants $150 to key it. Is there any way I can take the locking mechanism out without taking the column out? I'm having to take off work to go get it, so it's not like I've got days to pull the column and so on. Just trying to figure out a good way to unlock it so I can steer it into my trailer and into my shop. Any thoughts or suggestions? Thanks.
Re: How to unlock steering - 70 Cuda [Re: da50r] #1783112
03/18/15 09:09 PM
03/18/15 09:09 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Remove the lock rod from the lower column bracket in the engine bay.
Move bracket to rotate outer column.
You may have to tie it in place.
I am not sure if it will work without a key though.
I have gotten lucky a few times with keys to other cars, so if you have any spares or a pal with spares that may work too.
Re: How to unlock steering - 70 Cuda [Re: Alaskan_TA] #1783113
03/18/15 09:19 PM
03/18/15 09:19 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Ah. Yeah. Wonder if it bypasses the key that way?
Re: How to unlock steering - 70 Cuda [Re: da50r] #1783114
03/18/15 10:35 PM
03/18/15 10:35 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
my lock rods are missing and the steering wheel still locks...best way to do it I guess is to either front lift the car by the wheels or disconnect the column assy ..i would guess if you unplugged the harness and remove the 2 bolts off the dash you can turn the whole assy as one..I would go with the smaller tow truck with the wheel lift..using a floor jack to get it in position for the lift
Re: How to unlock steering - 70 Cuda [Re: AARCONV] #1783115
03/18/15 11:23 PM
03/18/15 11:23 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Is there a way to remove the ignition cylinder and go that route?
Re: How to unlock steering - 70 Cuda [Re: da50r] #1783116
03/18/15 11:33 PM
03/18/15 11:33 PM
Georgia
Steve Bryant Offline
Georgia
First, I will tell you the ignition switch is pretty cheap. I think I bought the switch and door locks for less than $50. I tell you this in case you get to the point where it needs to be broken...
Second, to get to the switch is pretty easy but you will need a gear or wheel puller to get the can off of the steering rod. You first remove the wheel, then you need to pull off the can. The can has two bolt holes down deep that you use for leverage to press out the can.
Once you get that off, there is a snap ring and then the you can remove the blinker section. Once you get that deep, you can just flip up the lock lever so the cog spins freely and the wheels will turn.
I found this photo online that shows how the lock works inside the column. The ignition switch is under this but you would need to press out the pin from this cog to get to it.
Just push that lever up and the cog and wheels will turn.
Re: How to unlock steering - 70 Cuda [Re: Steve Bryant] #1783117
03/18/15 11:58 PM
03/18/15 11:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If you can get the number off your ignition cylinder, Dan can cam make a key for you.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: How to unlock steering - 70 Cuda [Re: Alaskan_TA] #1783118
03/19/15 06:44 AM
03/19/15 06:44 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Take out a door lock and have a locksmith make a key shouldn't cost 160 bucks if you take the cylinder to him. A lot of Chrysler dealerships can do it too. Doors and ignition are keyed alike
Re: How to unlock steering - 70 Cuda [Re: MoparforLife] #1783119
03/19/15 11:35 AM
03/19/15 11:35 AM
Alberta, Canada eh!
70Cudha Offline
70Cudha  Offline
Alberta, Canada eh!
On the inside door panel remove the doorlock lever, remove the screw from armrest and screws from the door panel, remove the clip from the lock linkage, remove the lock cylinder retainer clip and take it to your local locksmith to get a key cut. quickest easiest fix. And hey you can inspect and perform maintenance to your window regulator at the same time.
Good Luck
1970 EV2 Barracuda Hardtop
1970 FE5 Barracuda Gran Coupe Convertible
1969 B5 Dart GTS 383
1968 TT1 Barracuda Convertible
1997 Ram SS/T
2008 3500 Ram Diesel
Re: How to unlock steering - 70 Cuda [Re: 70Cudha] #1783120
03/19/15 02:46 PM
03/19/15 02:46 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
His door key may not match the ignition key for sure.
Re: How to unlock steering - 70 Cuda [Re: AARCONV] #1783121
03/19/15 03:10 PM
03/19/15 03:10 PM
NJ
EV2RTSE Online content
EV2RTSE  Online Content
NJ
I believe this will in fact work as I seem to remember doing this with a parts car I had years ago.
locked steering [Re: EV2RTSE] #1783122
03/19/15 03:27 PM
03/19/15 03:27 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
If ya dont want to mess with the keys. Un do the horn pad. Pull wheel off back the big nut off down inside the can. And put wheel back on. Give wheel a good yank. The can will slide up. And the wheel inter lock will not interfere any more. Iv done it on more then one mopar
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: How to unlock steering - 70 Cuda [Re: CYACOP] #1783123
03/19/15 03:34 PM
03/19/15 03:34 PM
Georgia
Georgia
In my Cuda, the two did not match. I suspect someone swapped a door lock. I have since changed all three out to make them match.
Re: How to unlock steering - 70 Cuda [Re: 70Cudha] #1783124
03/20/15 11:12 AM
03/20/15 11:12 AM
Alberta, Canada eh!
70Cudha Offline
70Cudha  Offline
Alberta, Canada eh!
Good Luck
Alternately
http://www.ebay.com/itm/1970-1971-70-71-...f80&vxp=mtr
1997 Ram SS/T
Re: How to unlock steering - 70 Cuda [Re: da50r] #1783125
03/20/15 08:24 PM
03/20/15 08:24 PM
IMGTX Offline
IMGTX  Offline
It doesn't take long to pull the lock cylinder or remove the lock plate.
1. Disconnect the battery & remove the Steering Wheel. Remove the large nut holding the corrugated can on the steering column and use a puller with some long bolts to remove the can.
2. Remove the 3 screws holding the Turn signal Switch assembly and the 1 screw holding the lever to the switch.
3. Remove the snap ring holding the bearing to the shaft.
4. Remove the 3 screws holding the upper housing to the middle housing.
5. Disconnect the wiring under the column to give slack so you can move the upper housing out of the way.
6. Wiggle the Turns Signal switch up and out of the way. You can now pull a little slack out of the wiring you disconnected and freed in steps 5.
8. Wiggle or gently pry the upper column housing off of the middle column housing and pull it off the shaft. It's OK to let it hang on the Turn Signal Switch wiring if you need to but be gentle.
9. Remove the other snap ring on the shaft.
10. Pry up to remove the collar from the lock plate and then drive out the pin under the collar . Remove the lock plate.
11. Remove the two screws holding the column lock mechanism in place.
12. Under that plate you will see a small bolt. Remove it and the lock cylinder will come out. Later models have a small hole push a pin in it and pull out to remove the lock cylinder. Do not have keys in the lock cylinder.
13. Reassemble as needed.
Re: locked steering [Re: toplescuda] #1783126
03/21/15 04:23 PM
03/21/15 04:23 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
