Holley or Edelbrock ??
#1782997
03/18/15 07:51 PM
03/18/15 07:51 PM
Posts: 1,014 LEE, MASS
TOMRR
LEE, MASS
My Engine builder is steering me toward using an Holly over the Edelbrock Carb. I have a 1972 HP440 and having it brought up to 1969 HP 440 Horse power and Torque !! I like the Edelbrock and have run a 750 Performer on this engine in the past. The only thing I know about Hollies that they are not dependable and leak a lot or has that changed ?? Would like some input on this Thanks Tom C.
Re: Holley or Edelbrock ??
[Re: TOMRR]
#1782999
03/18/15 08:09 PM
03/18/15 08:09 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I have had great success with both. Holley for performance and Edlebrock for no worries. My opinion, and it has worked for me. If I had the linkage already for the Eddy and liked the way it worked in the past I'd go with it.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: TOMRR]
#1783000
03/18/15 08:15 PM
03/18/15 08:15 PM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
For a street engine I really prefer the Edelbrock/Carter carbs. I've had better long term drivability out of them. There were many times that we tuned a Holley to be a slightly stronger performer but went back to the Eddy for better manners.
[Re: TOMRR]
#1783003
03/18/15 10:00 PM
03/18/15 10:00 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Seek out Bob K...
Driver of the Hemi 'Cuda at the Pure Stock Drags...
He might have some input...
[Re: TOMRR]
#1783006
03/19/15 12:08 AM
03/19/15 12:08 AM
Posts: 12,362 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Another vote for the new Street Demon. The CarterBrocks are okay, but they use 50 year old tunes that just do not seem to have been updated. Holleys can do okay with some tuning.
Google the Street Demon and you will see that they have incorporated several cool features that help the carb do a better job on street cars.
Master, again and still
[Re: RapidRobert]
#1783008
03/19/15 02:20 AM
03/19/15 02:20 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Can only speak from my own experience: I'll never own another Edelbrock Performer Carb. I had (2) 1411 750's. One vaporlocked as soon as the motor was warm. Both had an off-idle stumble that I couldn't get rid of (and I tried until I was frustrated). With this motor, I moved to a Holley 750, and instantly the car ran perfectly. Since then I've always gone the Holley direction, and I've always been able to make them respond to simple adjustments. Currently running an 830 DP on my 451.
If i had to own an Eddy carb, I'd go to the AVS series.
[Re: StealthWedge67]
#1783010
03/19/15 09:16 AM
03/19/15 09:16 AM
Posts: 5,912 Athens, Greece
Pyper70
Athens, Greece
It's simple as this
If you are a weekend warrior looking to tune every single aspect of a carburetor and get maximum performance for hours and hours of trial and execution...
Holley
If you like to set it up once and have it remain like that forever...get in your car...turn the key and leave the scene...
Edelbrock
I have owned both...I had an 800cfm Holley on a 440 and it was professionally rebuilt. I even had the guy come out and dial it in to my Charger. It never ran right...I wanted to go to a car show so I took the 500cfm off my Slant 6 (modified) and my 440 worked BETTER with a 500cfm....well thats when I sold all my Holleys....Does the Holley work when you tear it apart and change the cam, the power valve, the jets, the balancing tube...YES!!! but I like to get in my car and drive it more than fix it
BTW, I run Two Eddy's 500cfm on my engine and I haven't had a single leak, stumble, or need to remove them from my engine in 5 years
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: RapidRobert]
#1783012
03/19/15 09:34 AM
03/19/15 09:34 AM
TOMRR
LEE, MASS
When I had the 750 Edelbrock on this 440 it ran great no issues .I do no know way my engine builder wants to use a Holly ? But I am looking at The Edelbrock EDE-1412 800 cfm Recommended for High-Performance street and light strip. Mind will only be driven on the street Thanks For All The InPut !!! Tom C.
[Re: gdonovan]
#1783016
03/19/15 07:24 PM
03/19/15 07:24 PM
Posts: 1,307 Laveen, Arizona
GTSDart340
Laveen, Arizona
I had the typical Holley. Leaked from the accelerator pump. Leaked from both ends of the fuel transfer tube. Leaked from the side of the rear float bowl. Leaked from the bottom of the float bowl. Needle and seat stuck, sprayed fuel out the float bowl vent... Finally got to the point that the truck wouldn't start (318 x2). Edelbrock, no issues. I have a 1406, its been on two 318s and a 360. Runs great, no problems.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
