69 340 Dart again... #1781830
03/17/15 02:06 PM
03/17/15 02:06 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Dad wants to make a few changes to the Dart. Right now it runs right about a 13.20-13.40. Lazy as hell in the 60ft. and pulls real hard thru the higher RPM's.
It's a street car that he's not interested in trying to race but he wants it quicker? He's 75 and I think its fast enough...but he'll get what he wants.
Specs are:
.060 over 69 block with 10.25-1 compression
Eddy alum head with a slight intake port blend job
M-1 intake (single plane)
Racer Brown ST-21 solid lifter camshaft (.254 at .050 .520 lift)
MSD distributor with advance set-up early all in at 2K timed at 36*
750 and 850 Holley little to no difference (would be open to a new 750 Demon)
3500 Convertor
3.23 gear
28" M+H Racemaster Slicks
I know the gear hurts it so I caved and am putting a 3.91 in it.
Still haven't ever checked the cam timing but plan on it in a few weeks. It feels like it needs advanced to me.
I want to degree it in and put a LD 340 intake (Dual plane) on it and leave it alone.
He saw where Racer Brown sells the 1.5-1.6 rocker kit and wants to put it in. The cam is already too big...I'm not sure this will help.
I'm not going to change the cam, convertor or heads.
This build was done using a bunch of good parts I already had...now I want to get the most out of what's here.
What say you?
Thx Guys...
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781831
03/17/15 02:13 PM
03/17/15 02:13 PM
Out West
408strokerdart Offline
Out West
Loose the single plane manifold. It's killing it with those 3.23 gears and cam combo. Get a Edelbrock RPM for it and that should help it.
Re: 69 340 Dart again... [Re: skicker] #1781832
03/17/15 02:17 PM
03/17/15 02:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well your putting in more gear.. thats gonna help..
check the cam... advance it some.. does the conv really
stall at 3500.. you can get that tweeked if needed..
the dual plane intake will help also
Re: 69 340 Dart again... [Re: MR_P_BODY] #1781833
03/17/15 03:16 PM
03/17/15 03:16 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
With that cam and 28" tires a 4.30 gear would really wake it up
What's the MPH thru the traps?
Try the 3.91 and a dual plane with the 750 for starters.
Re: 69 340 Dart again... [Re: Mr340] #1781834
03/17/15 03:22 PM
03/17/15 03:22 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
As said above, too much cam with the converter and gears, needs a dual plane and smaller carb. I had a pretty much stock 340 run your numbers with a 3.91 gear, but it was a 4-speed.
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 340 Dart again... [Re: skicker] #1781835
03/17/15 03:27 PM
03/17/15 03:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It'll like the 3.91 gears, after changing them I'd run it before I made any other changes. It'll be a different car.
Re: 69 340 Dart again... [Re: skicker] #1781836
03/17/15 03:47 PM
03/17/15 03:47 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
That cam really needs 4.56-4.88, and 4800-5000 converter, but I understand your choices. The only thing I could think is to try backing off on the total timing a couple degrees( 1 deg at a time). The LD-340 and 3.91's will help quite a bit.
Yeah, it's got a smallblock.
Re: 69 340 Dart again... [Re: MR_P_BODY] #1781837
03/17/15 03:53 PM
03/17/15 03:53 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Mike,
The convertor seems a little tighter than 3500. I attributed that to the intake and cam not allowing it to make good torque. I hoped with the gear change it will loosen the convertor up by raising the RPM's.
If the convertor does truly work on torque...and this combo doesn't build much...if more torque was introduced wouldn't it stall a little higher?
That was the reasoning I used for an intake swap...
Originally I didn't want to do a gear change as I thought it was a band aid and I was just covering up the real fix.
I thought if I could make it run as good as possible with the 3.23's... then changed to the 3.91's it would be that much better.
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781838
03/17/15 03:59 PM
03/17/15 03:59 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
A Racer Brown ST-21 is 254@0.050" and 0.520 lift. That cam needs lots of lead, start with at least 20* of initial timing. The dual plane intake and 3.91 gear will help tremendously in getting it out of the hole.
Re: 69 340 Dart again... [Re: urdustd] #1781839
03/17/15 04:11 PM
03/17/15 04:11 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
A Racer Brown ST-21 is [Email]254@0.050"[/Email] and 0.520 lift. That cam needs lots of lead, start with at least 20* of initial timing. The dual plane intake and 3.91 gear will help tremendously in getting it out of the hole.
Your correct...that's a typo on me...
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781840
03/17/15 04:26 PM
03/17/15 04:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike,
Your correct... more torque it will stall higher..
so yes if you can built more torque it will go up..
the gear is a torque multiplier also but thats after
the conv
Re: 69 340 Dart again... [Re: skicker] #1781841
03/17/15 04:33 PM
03/17/15 04:33 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Sounds like a good combo, 3.91 gears will really help and get the cam degreed so that is ruled out. Intake should help the 60 times and not lose much on top end. What is your fuel system? What size line?
My old 68 GTS 340 with stock X heads with 273 rockers and a smaller MP solid cam, 235 @ 50 and around .480 lift. degreed and advanced 4 degrees, 3800 stall 727, air gap intake, 4.10 rear with 26 inch drag radial, 750 DP holley carb. It took 20 degrees initial all in by 2200. Its was a little lazy off the line and ran close to what yours is running until I went to an electric fuel pump and regulator, it already had 3/8 fuel line. Got it down to 12.80's @ 105 in good air.
Re: 69 340 Dart again... [Re: gtsdude] #1781842
03/17/15 04:51 PM
03/17/15 04:51 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Fuel pump is a Holley...I think 6-7 psi with new -6 braided lines and a 3/8" sending unit. All lines for fuel and Transmission are AN.
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781843
03/17/15 05:23 PM
03/17/15 05:23 PM
P
Paul_Fancsali Offline
P
Try a set of 4.30s and try a 650 dbl pumper keep the jets at 69-70 and no more then 75 rear Get your total as high as you can without ping try hard for 40 degree's total + that car should be running at least a 12.5
Re: 69 340 Dart again... [Re: Paul_Fancsali] #1781844
03/17/15 07:30 PM
03/17/15 07:30 PM
CA
crackedback Offline
crackedback  Offline
CA
Engine is good for high 11's or better with a decent chassis/converter.
Get lots of initial timing on it. Get a bushing for the msd to decrease mechanical to 10 or 14 degrees. I'd bet it will take 24-26 initial timing.
An LD340 or air gap and 750dp will kill the M1 down low and be equal up top. Make the converter work harder too.
3.91's, try a shorter tire. A 26" tire would help a lot. 28" I'd run no less than a 4.30 and better a 4.56.
Re: 69 340 Dart again... [Re: crackedback] #1781845
03/17/15 08:39 PM
03/17/15 08:39 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
If you put 3.91 gears in it the convertor will be tighter. I put a 3.50 gear in my D50 (Did have 4.56) and the convertor stalled a lot more. At the time it went from 6.34 (4.56 gear) to a 6.39 (3.50 gear)in the 1/8.
I guess the convertor stalling more kept it from not slowing down to much.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 69 340 Dart again... [Re: 340B5] #1781846
03/17/15 10:17 PM
03/17/15 10:17 PM
Lehigh Acres, Florida
rickstershemi Offline
At Least 4.56.....what does the car weigh...????
My Challenger at 3200 lbs with 4.56 a similar 340 build (different cam) with worked X-Heads and a 750dp ran a best of 11.2 @ 117 in the 1/4....6700 at the stripe.
Rickster
Re: 69 340 Dart again... [Re: rickstershemi] #1781847
03/17/15 10:42 PM
03/17/15 10:42 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
It's basically curb weight with the heater box removed and aluminum heads.
It had 4.56's in it for about a week. HATED IT And yes it does run much better.
I followed him back from a show about 60 mph for about 12 miles.
I could've brained him running it that hard.
He doesn't hear real well and must not pay any attention to the tach. I'm trying to nail down a better combo with whats there. He gets out on the interstate and runs 70-75 with it now with the 3.23's. I'll have a hard time breaking him of that with the 3.91's.
No one has really addressed changing the rockers from stock 1.5's to a 1.5-1.6 combination.
Wouldn't that technically make the cam seem bigger?
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781848
03/17/15 10:48 PM
03/17/15 10:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It doesnt need more cam.. its too much right now but
with your changes it can help it... you need to look
at what that cam is installed at.. if you can advance
it 4*
Re: 69 340 Dart again... [Re: MR_P_BODY] #1781849
03/18/15 01:59 PM
03/18/15 01:59 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I bought a couple off set cam keys and a couple offset crank keys. When I tear the front off I wanted to have what I needed to put it back together after degree-ing it in.
...FAFO...
