Re: 69 340 Dart again... [Re: skicker] #1781850
03/18/15 02:04 PM
03/18/15 02:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought a couple off set cam keys and a couple offset crank keys. When I tear the front off I wanted to have what I needed to put it back together after degree-ing it in.
MP offers a offset key package.. can be bought from
Mancini's.... just in case you need more... see where
it is now but I would move it more.. even if its slightly
advanced now.. just check the V to P clearance
EDIT
I have moved a 108 lsa cam as far as 98* installed
but that killed my top end RPM... I had to back it
up to 101-102.. but at 98 it sure did have a bottom end
(torque)
Re: 69 340 Dart again... [Re: MR_P_BODY] #1781851
03/18/15 02:17 PM
03/18/15 02:17 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
(torque)
Your exactly opposite where I am...
He likes the feel of the power...problem is where its at he's already speeding before he gets to feel it.
I'd like it to hit a lot harder and am willing to sacrifice some top end to get there.
Sounds like it needs advanced beyond recommended...
...FAFO...
Re: 69 340 Dart again... [Re: skicker] #1781852
03/18/15 05:30 PM
03/18/15 05:30 PM
P
Paul_Fancsali Offline
P
Correct on cam it is too much for those gears, and no 4000 will never hurt a good 340 Run mine at that all the time when cruising Just be sure the cooling system can handle it and you are running a oil that is up to the task if needed
Definitly go with 4' advance on cam
Re: 69 340 Dart again... [Re: skicker] #1781853
03/18/15 06:18 PM
03/18/15 06:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I think a good convertor can make up for the 3.23's. HotRod did a torque convertor test years ago and it was suprising how well the highway gears would do with a good convertor. I think member Big Squeeze has a story where with a good convertor he was able to run very good times with 2.94 gears compared to a 4 something gear in the same car IIRC
Re: 69 340 Dart again... [Re: WO23Coronet] #1781854
03/18/15 07:15 PM
03/18/15 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
But he has a small list of things that will NOT be
changed and the conv was one
Re: 69 340 Dart again... [Re: skicker] #1781855
03/18/15 09:03 PM
03/18/15 09:03 PM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Don't worry about the 70mph on the interstate , you could have bought that car new with a 3.91 gear when the speed limit was 70 and it had a lot shorter tire on it when mother mopar put it together.
