Holly 750 dp application for air grbbr hood 440 #1781808
03/17/15 12:16 PM
03/17/15 12:16 PM
canada
W
WAPITI Offline OP
WAPITI  Offline OP
W
canada
thanks moparts. I have searching the archives for info that would generally help me find a good aftermarket intake with a holly 750 dp that would fit under a air grabber hood.
I know its probably a loaded question and I most likely will have to modify it some. Im new.
thanks again
Re: Holly 750 dp application for air grbbr hood 440 [Re: WAPITI] #1781809
03/17/15 06:44 PM
03/17/15 06:44 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
ok , no takers .
my experience with a 69 Roadrunner , 440RB and air grabber . Used a Edelbrock Performer , close to stock height . Did have a 383 air cleaner base , rubbed on bonnet assembly . Owner bought a fibreglass drop base off one of the posters here - Blofish / Paintitblack ? maybe.
fits fine now . did have to trim edge slightly on base and airgrabber to fit MSD distributor
sorry if I have wrong supplier name
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Holly 750 dp application for air grbbr hood 440 [Re: WAPITI] #1781810
03/18/15 10:49 AM
03/18/15 10:49 AM
canada
W
WAPITI Offline OP
WAPITI  Offline OP
W
canada
Thanks Tex
Re: Holly 750 dp application for air grbbr hood 440 [Re: WAPITI] #1781811
03/18/15 01:08 PM
03/18/15 01:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
CH4B is a better than the performer. I think a Holley S/D will also fit. You might need a drop base.
Coming soon!!!!
