Hemi Oil System Question
#1781190
03/16/15 12:58 PM
03/16/15 12:58 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Ok, just got the new cam in my 472 Hemi. I'm using a custom grind solid as some folks here indicated my off the shelf hydraulic could be leaving some power on the table. Anyway, I know one of the advantages of solid lifters is higher RPM effectiveness. But a question I have is this: at what RPM do folks recommend deviating from stock internal oil system? I had heard that higher RPMs that the Hemi's oil system tended to give up. I never paid attention because I assumed it was greater that 6500 rpm. Since I was originally using a hydraulic I didn't care. But now that I may be living in the higher RPM range, I am concerned.
At what RPM is stock oil system deemed inadequate? What are options? Is the deficeincy in the pickup? Or downstream of the pump? I happen to have a used single pickup Moroso cover setup that came with my box of parts. But I am not sure it would clear the engine mounts. How do these special covers work? I assume I plug the internal pickup port and run a pickup from the pan to the cover assembly. I was looking at Moroso's web site and couldn't find any directions for their set up.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Hemi Oil System Question
[Re: AndyF]
#1781195
03/16/15 04:05 PM
03/16/15 04:05 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
I'd stick with the stock system as long as possible. The external oiling lines are a hassle to deal with on a street car. Keep an eye on the oil pressure gauge and see how it goes. Personally I'd add an accusump before I'd use the external line setups in a street car.
We, myself and another couple that I did all the motor work on, drag raced street Hemi for many years using the stock 1966 to 1969 and later the 1970/71 Street Hemi oil pans and stock pickups with no oiling issues ever. We always made sure the oil pan was full when cold before going racing, I willcalibrate the dipsticks when assembling the motor Both of those motors with stock lifters, solids on the pre 1970 and hydraulics on the 1970 Cuda would pull hard to 7000 RPM so that is where we shifted both of them at, one 4 speed and one 727 We did use 50 Wt oil in them back then, which I would never do now I like and use 5W20WT in my race and street motors now It flows and has pressure immediately on start up
[Re: RoadRunner]
#1781196
03/18/15 11:12 AM
03/18/15 11:12 AM
RoadRunner
Thanks all. I did a quick mock up and the oil pump cover feed line would interfere with motor mount. I would need to have the cover with the feed line on the side I guess. The cam I have looks to have power range of 3500 to 6500 rpm. So I am going to stick with stock interal pick up. I went with larger pan (7 qt IIRC). Looks like I should be OK with stock pickup and deep sump pan. I do like the idea of an accusump. I just may look into one of those.
[Re: RoadRunner]
#1781197
03/18/15 03:12 PM
03/18/15 03:12 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I'm running the swinging pickup and deep tie-rod tube Milodon pan in my Wedge 'Cuda. It's a 4.15 stroker motor and we did have to grind a bit on the pickup boss in the block to get the crank to rotate without hitting anything. I did have to trim the motor mount support on the K-Frame a bit to get the external line to fit. I have a one piece cover from a guy out in Oregon (?) that's CNC'ed out of a chunk of aluminum with a thin hardened steel plate between the cover and the pump gears. It all works fine but it is a lot of trouble for a street car. The pan hangs low, the lines are semi-exposed and it took me two shots to get it to seal up and not drip any oil. If I were to do it again, I'd probably just go with the road race pan.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: B G Racing]
#1781199
03/19/15 06:21 PM
03/19/15 06:21 PM
Posts: 7,493 Minnesota
Hemi_Joel
Minnesota
Lots of us have run 7500 rpm with the internal pick up. While observing a sight guage on the pan, reving the motor, the oil in the pan gets scary low, so I put in 2 extra quarts. I also accidentily went to 9300, and a rod bearing starved, welding it to the crank. So the limit is somewhere between 7500 and 9300 rpm.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: B G Racing]
#1781204
03/20/15 12:36 PM
03/20/15 12:36 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
Years ago,Chrysler engineers did a study on the oiling system on a hemi.The concluded that 10 quarts of oil would have to circulate 3 times on an adverage 10 second 1/4mile pass.At any given time 5+ quarts were suspended in the oil passages and top end.They recommended at least a 10 quart sump to retain sufficient oil at the pickup.
I guess I better keep my car from the occasional pass down the track then
[Re: B G Racing]
#1781205
03/20/15 02:13 PM
03/20/15 02:13 PM
Cab_Burge
Years ago,Chrysler engineers did a study on the oiling system on a hemi.The concluded that 10 quarts of oil would have to circulate 3 times on an adverage 10 second 1/4mile pass.At any given time 5+ quarts were suspended in the oil passages and top end. They recommended at least a 10 quart sump to retain sufficient oil at the pickup.
I can't imagine a hemi with stock oiling to the rockers circulating that much oil in 10 seconds , especially back in the day when Mopar engineers where still using 50 wt. oil in the drag cars Even with the stock loose lifter to lifter bore clearances and rod and main bearings clearances at or above 5000 RPM All of the 1966 to 1969 Street Hemi cars came with a oil pan with 5 quarts, every Hemi car owner made more than one blast fo 15 seconds at WOT, not very many had rod oiling problems back then, the 383 and 440 did though, lots of them did The bean counters looked at the Five year and Fifty thousand mile warrenty as a way to lose money if the parts wouldn't hold up that long I do remember Tom Hoover saying at one of the drag seminar on the west coast to make sure and run at least 5 quarts in any of the B/RB, Hemi production oil pans that would be drag raced back in the mid 1970s in NHRA stock, he also said increasing the oil pan capacity in SS was mandatory for engine longivity Sorry for doubting this comment on 5 quarts being suspended Mike Landy had said that they had done some engine dyno testing with a big capacity oil pan with a sight gauge on the drivers side of that oil pan and they saw about 3 quarts of oil decreased on the gauge, suspended, at or above 6500 RPM on thier testing
