Re: Torque strap or solid motor mount?
[Re: 67Satty]
#2395921
10/31/17 10:20 AM
10/31/17 10:20 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
All these jobber cheap motor mounts are junk , even before trying this modification Two I got from O Reilly's Anchor 2250 the welded nuts where crooked and one fell off in the box , serious Metal looks thin as paper Two I got from Napa , bolt studs for mount need to bee shortened but the problem with there's was the welded nut and opposing holes looked fine but where a 1/2" further away from the mounts then factory so they didn't sit flush on the K Frame when running the bolts through , mounts sat at least 1/2" off the Frame Who the hell sells a decent motor mount to begin with before doing this mod ? Something that least fits proper 432 Stroker Motor will bee done this week for my 71 Superbee
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: BDW]
#2395930
10/31/17 10:35 AM
10/31/17 10:35 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I see Schumacher sells a revised bracket now where it bolts to the side of the block. I have the old style on my dad's road runner. That bracket broke when it was on my cuda (w/ a 600 hp 440), welded it back together and lasted for a while. Put it on my dad's 500 hp 4 speed road runner and it broke again after a few months. I'm about to call and see if they'll send me the revised bracket.
If I had to do it again, I'd put a solid mount on the driver's side. If it wasn't such a PITA to change w/ the motor in the car I'd do it now. I don't like the looks of any type of strap/chain/cable/etc.
[Re: an8sec70cuda]
#2396120
10/31/17 04:00 PM
10/31/17 04:00 PM
an8sec70cuda
If I had to do it again, I'd put a solid mount on the driver's side. If it wasn't such a PITA to change w/ the motor in the car I'd do it now. I don't like the looks of any type of strap/chain/cable/etc. I sent Schumacher an email this morning since they are in Washington state and they were all likely still in bed when I read this. A lady from there called me a lil while ago and asked for my address so she could send me the revised bracket free of charge. She said the original brackets were cut on the CNC against the grain when they were supposed to be cut w/ the grain. When they started having breakage problems, they redesigned it as well as corrected the cutting error. Anyways, figured yall might like to hear that they're a good company to deal with!
[Re: BDW]
#2396279
10/31/17 09:03 PM
10/31/17 09:03 PM
Posts: 4,726 Florida
BDW
What bracket are you taking about? The U-shape channel that bolts to the K-member? Here's my install, blends in nice
[Re: BDW]
#2396532
11/01/17 10:20 AM
11/01/17 10:20 AM
an8sec70cuda
No, the bracket that attaches to the motor mount boss on the side of the block and then the top eyelet the "rod" bolts to it. It broke in the curve under the bolt. The revised bracket is much smaller, just a flat piece w/ a slight curve in it.
[Re: FurryStump]
#2397583
11/02/17 11:31 PM
11/02/17 11:31 PM
Posts: 2,820 Connecticut
FurryStump
Connecticut
Picture of mount
