Re: Gen 3 lifter use question. Or: Sometimes I'm SO stupid
[Re: cudaman1969]
#1780688
03/15/15 10:00 PM
03/15/15 10:00 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
If you want it to run, you need to pull the head.
Mopar to the bone!!!
[Re: ntstlgl1970]
#1780690
03/15/15 11:28 PM
03/15/15 11:28 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
this is from a chrysler training manual:
5.7L HEMI® MDS Operation Both four- and eight-cylinder configurations of MDS have even firing intervals,providing smooth operation. Two cylinders on each bank are active when the engine is in four-cylinder mode – every other cylinder in the firing order. All of the cylinders that are deactivated have unique hydraulic valve lifters that collapse when deactivated to prevent the valves from opening. Engine oil pressure is used to activate and deactivate the valves. Oil is delivered through special oil passages drilled into the cylinder block. Solenoid valves control the flow. When activated, pressurized oil pushes latching pins on each valve lifter, which then becomes a “lost motion” link. Its base follows the camshaft, but its top remains stationary, held in place against the pushrod by light spring pressure but unable to move because of the much higher force of the valve spring. Deactivation occurs during the compression stroke of each cylinder, after air and fuel enter the cylinder. Ignition then occurs, but the combustion products remain trapped in the cylinder under high pressure, because the valves no longer open. No air enters or leaves. During subsequent piston strokes, this high-pressure gas is repeatedly compressed and expanded like an air spring, but fuel is not injected. 2009+ MY 5.7L HEMI® MDS lifters where redesigned to allow for more camshaft lift when deactivated. These newer lifters can be used in prior model year 5.7L engines.
[Re: Barry70GTX]
#1780692
03/16/15 03:35 PM
03/16/15 03:35 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Not sure if anyone has ever posted a pic of the lifters and see lots of confusion about these, so here is what they look like. The first pic is a conventional Hemi lifter. The second is a an MDS lifter. They are dimensionally identical. The hole in the side where you can see the pin is what makes them work. This lifter beat out the trunion bearing which let it bounce and destroy the internal body, which is why the pin is turned. Normally the pin sticks through the hole and locks the lifter halves together, making it a conventional lifter. When oil pressure is applied from the solenoid (MDS mode activated), the pin is pushed in, and the internal body can collapse enough to prevent valve lift, but not enough for the pushrod to loose tension to the rocker. ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_2143_zpsjr7yw7wh.jpg) ![](http://i1060.photobucket.com/albums/t445/340cuda/IMG_2144_zpssguf5tc5.jpg)
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1780693
03/16/15 10:39 PM
03/16/15 10:39 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Nice explanation and pics. I see a lot of the MDS lifters turning and tapping lately in our dealership. Mostly on the later VVT engines.
[image][/image]
[Re: sgcuda]
#1780694
03/21/15 10:31 PM
03/21/15 10:31 PM
sgcuda
FYI, just replaced the plastic plugs with a set of MDS solenoids. Firing on all 8 cylinders again. ![](/ubbthreads/images/graemlins/boogie.gif) So yes, you can leave MDS lifters in your engine and just leave the solenoids unplugged, engine will run on all 8 all the time.
[image][/image]
[Re: cudaman1969]
#1780696
03/21/15 11:10 PM
03/21/15 11:10 PM
72Swinger
Nebraska
I take that as it has more plunger travel in MDS mode for higher lobe lift to be used.
[Re: 72Swinger]
#1780697
03/21/15 11:17 PM
03/21/15 11:17 PM
Posts: 8,355 fredericksburg,va
cudaman1969
fredericksburg,va
Yea sounds right, I was thinking the other way
