Leaf spring ? #1780610
03/15/15 03:14 PM
03/15/15 03:14 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Has anyone ever purchased leaf springs from springs and things.
Re: Leaf spring ? [Re: CARMAN] #1780611
03/15/15 06:48 PM
03/15/15 06:48 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Yes, several times. Good people who know their springs. BTW - unless you're running super stock springs, the spring pack should be straight and level with the car sitting on them. That's the way Mopar designed them and the way leaf springs work best.
Re: Leaf spring ? [Re: CARMAN] #1780612
03/15/15 07:31 PM
03/15/15 07:31 PM
Not personally but I've read so many good comments regarding them (on here) that I would have no problem recommending them (& I'd get 1" arch over stock)
Re: Leaf spring ? [Re: CARMAN] #1780613
03/15/15 08:04 PM
03/15/15 08:04 PM
USA
Hooligan Offline
Hooligan  Offline
USA
I purchased a set with 2 inches more lift way back around 1999.
One of main leafs had a twist in it so bad that I didn't even try to install it. They paid for return shipping of both leaf springs and built me a complete new set at no charge. I was amazing by that, and they raised my car 2 inches perfectly. I assume the same people own the company, so buy with confidence!
Re: Leaf spring ? [Re: Hooligan] #1780614
03/15/15 09:24 PM
03/15/15 09:24 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Bought a set for my '57 Plymouth a few years ago, and I am satisfied with them.
It's Swifty! Swifty, you toad sucker!
Re: Leaf spring ? [Re: zrxkawboy] #1780615
03/15/15 10:43 PM
03/15/15 10:43 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I have purchased springs and other suspension parts from Springs and Things for at least 15-to 20 years. No problems , I would highly recommend them.
Re: Leaf spring ? [Re: CARMAN] #1780616
03/16/15 08:58 AM
03/16/15 08:58 AM
Back in Blue Jersey.
P
polara71 Offline
polara71  Offline
P
I just purchased my 5th set from them. I try and replace springs whenever I pick up another old car... As always, good service, good products and quick shipping....
I have always ordered the one inch over stock as already suggested. I also now purchase new hardware.
Re: Leaf spring ? [Re: polara71] #1780617
03/16/15 03:02 PM
03/16/15 03:02 PM
New Lenox il.
CARMAN Offline OP
CARMAN  Offline OP
New Lenox il.
Thanks for the info i will be ordering a set this week.
Re: Leaf spring ? [Re: CARMAN] #1780618
03/16/15 07:18 PM
03/16/15 07:18 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Why is 1 inch over stock suggested, is it to allow for sag or just an appearance preference?
Re: Leaf spring ? [Re: Ply72rr] #1780619
03/17/15 02:06 AM
03/17/15 02:06 AM
I would (surely) think it is for the sag. almost everything takes a set/ages. You can work with the front/rear shackles to adj height slightly as needed
Re: Leaf spring ? [Re: Ply72rr] #1780620
03/17/15 09:50 AM
03/17/15 09:50 AM
P
polara71 Offline
polara71  Offline
P
Why is 1 inch over stock suggested, is it to allow for sag or just an appearance preference? [/quot
I do it for both those reasons, plus when the trunk is loaded it levels the car out.....
