Re: Radiator cap
[Re: Alaskan_TA]
#1778952
03/13/15 08:04 PM
03/13/15 08:04 PM
Posts: 1,553 Sweden
71redcuda
Sweden
I checked Bob's site & did not see them listed or mentioned, so I did not know he had them.
Same here, if i knew he had correct ones i would have bought one.
Re: Radiator cap
[Re: ]
#1778953
03/13/15 08:45 PM
03/13/15 08:45 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
here is a pic.
![](http://i1200.photobucket.com/albums/bb334/resq302/1969%20GTX%20convertible/IMG_0238.jpg)
I might have some better pics of it over on my resto thread I did on my Dad's 69 GTX vert. http://www.forbbodiesonly.com/moparforum...ory-specs/page9
I'll bet the cap on this radiator is an original. Other than the one we did for Bob, none of them had the correct bump out at both ears on the first ledge. One of the caps clocks to far because the locking tangs are not wide enough and another has a spring that doesn't open until 22 lbs or more of pressure which is not good for an old style radiator.
Bob may not be advertising them separately because he needs them for his radiators, if you need one, I might have a couple to spare.
Re: Radiator cap
[Re: HEMICUDA]
#1778954
03/13/15 10:06 PM
03/13/15 10:06 PM
Posts: 21,512 It's a dry heat
gtx6970
It's a dry heat
here is a pic.
Looks like the one Dales Cuda Shop makes
Re: Radiator cap
[Re: Kilrbee]
#1778956
03/14/15 03:44 AM
03/14/15 03:44 AM
HEMICUDA
Medina, Ohio
They aren't the same!Bob had them made for him because of the poor quality of the existing repops.
You are correct Brian, we did those for Bob last year for the radiators he makes.
