Carbs: thinking outside the box. #1777846
03/12/15 02:32 PM
03/12/15 02:32 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
If you don't think outside the box, you may be stuck inside the box. I like a few of these ideas as I've noticed fuel stains on my windshield and suspected fuel my be getting sucked out of my fuel bowl vent tubes by incoming air. The old rubber hose trick may work but these look pretty trick.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777847
03/12/15 02:33 PM
03/12/15 02:33 PM
PA.
"Little"John
"Little"John
PA.
2.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777848
03/12/15 02:33 PM
03/12/15 02:33 PM
PA.
"Little"John
"Little"John
PA.
3.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777849
03/12/15 02:34 PM
03/12/15 02:34 PM
PA.
"Little"John
"Little"John
PA.
4.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777850
03/12/15 02:42 PM
03/12/15 02:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used the plug boots before.. or the hose.. I
never tried the brass fittings.. I didnt think they
would seal on the vent tubes
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777851
03/12/15 02:52 PM
03/12/15 02:52 PM
Mark Whitener Offline
More over here. It's more about maintaining balanced atmospheric pressure to the bowls, that is what pushes fuel into the engine. When pressure at the vents are disrupted the fuel curve gets messed up.
http://racingfuelsystems.myfunforum.org/viewtopic.php?f=25&t=15
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Carbs: thinking outside the box. [Re: Mark Whitener] #1777852
03/12/15 03:00 PM
03/12/15 03:00 PM
PA.
"Little"John
"Little"John
PA.
I like it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Carbs: thinking outside the box. [Re: pittsburghracer] #1777853
03/12/15 03:02 PM
03/12/15 03:02 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The holley truck avenger comes with one already!
