Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777633
03/13/15 10:14 PM
03/13/15 10:14 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Couldnt you just take the indy plate and adjust it to fit? Cut the sides down to fit and then use silicon to fill the gaps?
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Dodgeguy101] #1777634
03/14/15 12:45 AM
03/14/15 12:45 AM
State of confusion
Thumperdart Offline OP
State of confusion
Its already installed with a paper gasket between the head and pan and just the metal tray to manifold with the blue hylomar between each so we'll soon see.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777635
03/14/15 02:54 AM
03/14/15 02:54 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
hylomar that is the ticket. I got some when I did a fuel tank on an RV for the sending unit. Apparently it is gas proof. It is kind of a pet peeve to see blue silicone on an intake manifold.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: littleVAL] #1777636
03/14/15 03:23 AM
03/14/15 03:23 AM
State of confusion
State of confusion
Thats the stuff right there and can't wait to drive it........
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777637
03/14/15 03:46 AM
03/14/15 03:46 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Use a stock tin and mod it...
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777638
03/14/15 11:35 AM
03/14/15 11:35 AM
Monroeville Ohio
Traven Offline
Traven  Offline
Monroeville Ohio
I have RPM heads and a Victor intake. I used 1/4" aluminum and beveled the edges where it meets the heads. A small bead of clear silicone along the edge and it isn't noticeable at all. polished it up, looks good, No leaks. I do have to trim the bottom of the intake gasket to get it to align. Any sheet metal or 2 piece I've tried ends up leaking. Had a 2 pc I made flanges and bead rolled that looked and worked good (16ga ) on the street but a couple passes at the track and it would leak. The Indy 1pc has way too much gap to seal on an RB with RPM 's, at least on mine anyways.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Traven] #1777639
03/14/15 11:59 AM
03/14/15 11:59 AM
State of confusion
State of confusion
I will make one next time to fit and not leak but I am moving to Vegas soon so I will do it then.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777640
03/15/15 07:01 AM
03/15/15 07:01 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
What heads are those cos I thaught very few fit rpm heads.
these are Stage 6 & no one, & i mean no one makes a valley plate for these on a B engine.
Re: ONE PIECE INTAKE MANIFOLD VALLEY PAN...... [Re: Thumperdart] #1777641
03/15/15 03:22 PM
03/15/15 03:22 PM
State of confusion
State of confusion
Now we're rockin and have to jet down a bit but the darts flyin again and the plugs are clean. Thankxxx 4 the tips.
