360 main Rear sump drag pan #1777051
03/11/15 03:15 PM
03/11/15 03:15 PM
Maryland
340_Dart Offline OP
340_Dart  Offline OP
Maryland
Whats everyone running? I am piecing together parts for my R3(360 main) motor and having trouble finding a good pan design to use. The motor is going to have an external oil pump and i plan on putting a swinging pickup in the pan. My car is running a STR coilover K-member, so i wont have an issue needing to fit a rear steer draglink. I've been looking at pan designs online and pretty much have decided i want a pan with a full length windage screen and a passenger side kick out to keep oil from traveling up the side of the pan into the block. Any pictures and/or company part numbers are appreciated. thanks - Andy
Re: 360 main Rear sump drag pan [Re: 340_Dart] #1777052
03/11/15 03:55 PM
03/11/15 03:55 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
360 truck pans are rear sump I believe. nothing with a kickout that I'm aware of but you maybe able to add a side sump and a full length windage screen.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 360 main Rear sump drag pan [Re: Jerry] #1777053
03/11/15 04:22 PM
03/11/15 04:22 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Someone out there makes an adapter for the 360 main to a 340 pan. I have one from shady dell I got years ago. It takes a good amount of silicone but has worked great.
68 Barracuda Formula S 340
Re: 360 main Rear sump drag pan [Re: Bad340fish] #1777054
03/11/15 05:42 PM
03/11/15 05:42 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Check out Kevko . I have one and about to buy another. Just be sure to clean the welding slag.
Re: 360 main Rear sump drag pan [Re: 340_Dart] #1777055
03/11/15 06:11 PM
03/11/15 06:11 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I'm running a moroso rear sump 360 oil pan, but they don't make it anymore. In my opinion I would get a kevco rear sump kick out oil pan and call it a day.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
