Page 1 of 3 1 2 3
Just got an estimate on my 2005 Dually Injectors.?? #1776939
03/11/15 01:00 PM
03/11/15 01:00 PM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
Hey guys. First off I will disclose I know basically nothing on this diesel cummins. I simply drive it everyday. It has 265K miles and have not had to crack a bolt on the engine. Tranny is another story.
I am getting ready to do a cosmetic overhaul this summer and am trying to get the drivetrain in similar condition before I add a new dually bed and paint the entire truck. I just changed a cracked exhaust manifold and at that time I mentioned to my diesel mechanic to tell me anything that needs attention. He stated my injectors are getting very noisy and will need to come out at some point in the near future. He said be prepared to spend $2800 to put new ones in... $2800, I am still frothing at the mouth. For 6 tiny injectors. The most expensive ones I can find on ebay are $1100 a set; so is the labor that intensive. Secondly if they are that expensive then why are they that expensive? Thanks for any input.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776940
03/11/15 01:15 PM
03/11/15 01:15 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
A big part of that will be parts markup. Mechanic Shops don't like it when you supply your own parts because they buy them at the local parts store and charge you markup. If you're not in a hurry you can order them and save some money that way. Then there's the labor. Changing diesel injectors is not the same as changing gas injectors. Diesel ones do take longer.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: DaytonaTurbo] #1776941
03/11/15 01:34 PM
03/11/15 01:34 PM
Guitar Jones Offline
Well let's see, first off they are electronic. Working these things under 20K+ psi isn't like a gas injector. They operate under high voltage. Then to change them you remove the valve cover, all the fuel lines, remove the tubes that fuel lines attach to, then remove all the rockers and the wiring harness. Then you can remove the injector hold downs and the injectors. Don't forget gaskets, seals and washers plus adjusting the valves when you put it back together.
On top of that if you don't know what you're doing you could potentially electrocute yourself or lose some fingers.
Yeah, it's just six little injectors.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Guitar Jones] #1776942
03/11/15 01:41 PM
03/11/15 01:41 PM
Far Northeast.
Far Northeast.
Like I stated I don't work on diesels. Don't get me wrong I understand there is more than meets the eye which is why I cringe when people react to the cost of a paint job or restoration. I just wanted to know what it entails. Now I do. Thanks for the input.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776943
03/11/15 01:46 PM
03/11/15 01:46 PM
I just looked around at the diesel sites and $450/injector seems about the norm. That's $2700 for six of those puppies. Your 2005 is a common rail, much more expensive then the old 12 valve mechanical injectors.
What you are seeing on fleabay for $1100 is reman injectors.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Guitar Jones] #1776944
03/11/15 01:58 PM
03/11/15 01:58 PM
Far Northeast.
Far Northeast.
Ahh. So he is right on the money at $2800 then. Going to be an expensive summer I see. Needs six new tires too... Uggg. Pretty bad when my six tires are 1/2 the price of the injectors.
Thanks for the input. Just wanted to double check before I had it done.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776945
03/11/15 03:30 PM
03/11/15 03:30 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You are lucky. Most are on their 2nd or 3rd set of injectors with that kind of miles. Clean fuel is the key to making them live. I would recommend an improved 2 micron fuel filter setup to help them last.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776946
03/11/15 04:35 PM
03/11/15 04:35 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
There's no way I'd throw that kind of money at a 265K motor, Cummins included. $2800 could get you a good used motor with half the miles.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Lefty] #1776947
03/11/15 05:12 PM
03/11/15 05:12 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
A used '05 5.9 Cummins for $2800? I don't know, that sounds pretty cheap, even with 1/2 the miles it seems like the injectors on the used motor would be on borrowed time, plus swapping a Cummins is probably a lot bigger job than doing injectors, plus, for a Cummins, it's only about 1/2the way used up at best. That doesn't make any sense to me
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Lefty] #1776948
03/11/15 05:36 PM
03/11/15 05:36 PM
Really? Where? I'll buy two at that price.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Guitar Jones] #1776949
03/11/15 06:18 PM
03/11/15 06:18 PM
Far Northeast.
Far Northeast.
The truck is going absolutely fine now. I am guessing many of these dually style trucks get used they way they are suppose to get used. Hauling, trucking down the interstate, etc with much of the time sitting, waiting for the next trip. Not mine, its my daily driver and with my job 1/2 of the week and am pounding on the miles. The largest thing I haul during the week is a tape measure. Don't get me wrong it has hauled many, many mopars however it is also my daily driver. I need to stop that pretty soon as I know those are waisted miles on this truck and it is now getting older. My diesel mechanic is floored that I have not replaced the fuel pump and or my injectors. The truck is not blowing white smoke it is simply getting louder and idles down a little rough and erratic. I bought this truck new for $52,000 and it is the first truck I have ever kept long enough to pay off. My wife thinks I am crazy for putting money in it but those payments were large and hurt to send out each month and I am not doing it again. So I will gamble on the engine and keep this thing running. If the motor goes I will have to find another one. I bought this bed for $500 and it will be painted black and installed this year, with new tires, seat covers and a new carpet. Hopefully I will have a new looking truck again and will last a while. We'll see and hopefully it's not a mistake.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776950
03/11/15 06:45 PM
03/11/15 06:45 PM
I've spent way more than that on my 1st gen. but I agree with you, those large payments are tough. I like not having payments so I'm keeping this truck.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: mymcodebee] #1776951
03/11/15 10:24 PM
03/11/15 10:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I own a repair shop and yes we do mark them up, most shops are around double what they pay for them at the parts store (mine is not that much), if you do a large volume like I do you get a significant discount over a walk in customer. Reason is when parts are wrong or go bad in the warranty period we often times have to eat the labor not to mention the hastle of getting the parts store to give you new parts and asociated parts. If you bring your own parts to me I am happy to do the work for you but I am not doing them free when your e-bay remans go bad or don't fit or... If I supply parts there is at least a 12 month 12,000 warranty where you bring it back and don't worry about it when they go bad I just fix it.
The labor time on there is only 3.6 hours, that is about right on in my expience.
All this shows why I don't drive a diesel, I can replace my whole truck for little more than the price of injectors on yours. I just replaced a complete V10 engine in a customers truck $1400 out the door.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: HotRodDave] #1776952
03/11/15 11:46 PM
03/11/15 11:46 PM
Louisville, KY
E
E-Ticket Offline
E-Ticket  Offline
E
Louisville, KY
You guys are scared of a 265K mile Cummins motor.....???....really...??? Not me....not if it has been taken care of. Keep good maintenance and you'll wear the truck out before you wear that motor out........
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: E-Ticket] #1776953
03/12/15 12:53 AM
03/12/15 12:53 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I know diesel isn't the answer to everything but literally you couldn't give me a V10, Gasoline up here is still $5/gallon, unless someone is buying my gas I don't want a V10 under any circumstances. My Cummins is 10 years old and I've done oil changes, fuel filter changes and one injector line, my truck will pull anything, keep your gassers.
Sheldon
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Guitar Jones] #1776954
03/12/15 02:25 AM
03/12/15 02:25 AM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I recently replaced the injectors in my '03 CTD myself. New Bosch - not cheap, but I expect to get another 230,000 out of it.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: E-Ticket] #1776955
03/12/15 02:32 PM
03/12/15 02:32 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The motor don't scare me, the injectors do, and if you don't notice a minor problem it can cost you an engine. 265,000 is about double when we start seeing injectors go bad.
As for V10 VS cummins my observations
12 mpg VS 18 mpg
$2.18 gal VS $2.83
$18,166 VS $15,722 to drive 100,000 miles $2400 difference, buy one set of injectors and the difference is GONE! And that does not count oil changes $100 ea every 5K $2000 diesel $35ea every 5k $700 V10 and fuel filters are $50 every 20,000 or so adds another $250 over the 100,000 miles. And the real kicker is the premium you pay to buy a diesel, they cost twice as much or even 3 times as a same year V10. The V10 truck would have to be worth absolute zero when you are done to use the "resale is higher" argument. Just looking at fuel cost and buy in you still save money with a v10, if you are not paying $5000 less than a diesel you are paying too much for a V10. The only difference is your engine sound don't say "big rig" and you can't roll "coal" on a prius.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: HotRodDave] #1776956
03/12/15 04:46 PM
03/12/15 04:46 PM
Missouri U.S.A.
Missouri U.S.A.
You are not going to be able to buy a salvage 5.9 cummins with less than 150K miles for around $2800. Aint gonna happen. They are bringing 4 to 5K or more in my neck of the woods. If the truck is yours free and clear you should fix it and go on. With 265K on the clock, it owes you nothing. Everyone thinks they can drive these trucks for 500,000 miles and never open the hood. Not the case. Its just the way it is. I tell my customers all of the time you can do a lot of repairing vs the cost of a new truck. They have become ridiculously expensive to purchase new and many have decided to keep driving what they already have. Most of them say they cant justify a new truck payment as much or more than their house. Look at it this way, Whats $2800 bucks towards a new one? 4 or 5 payments maybe?
10.02@134
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: HotRodDave] #1776957
03/12/15 05:08 PM
03/12/15 05:08 PM
12 mpg VS 18 mpg
$2.18 gal VS $2.83
I had an 89 diesel dually 5 speed I bought brand new, truck got over 26 MPG. When the V10's came out in 94 I had to drive one so I go to the owner and ask to drive the first one they get.
I took it out and it ran great, good power and a nice truck. When I got back he asks me how I liked it. I said it's too quiet and it doesn't stink. I bought a 96 later with the V10. 10 MPG, that's 10, no matter what I did, man did I miss my diesel. If the diesel would have been a club cab I would have kept it. When it was time to get rid of the 96 I got another diesel and have been driving them ever since. As much as I liked the V10 I'll never get another gas truck. The mileage difference when towing is like 6 for the V10 and 14 for the diesel pulling my 30 foot enclosed.
Re: Just got an estimate on my 2005 Dually Injectors.?? [Re: Guitar Jones] #1776958
03/12/15 05:40 PM
03/12/15 05:40 PM
Quantico, VA
ParaFrog88 Offline
ParaFrog88  Offline
Quantico, VA
I just did my 06 Ram 3500 DRW cummins.
I picked up the injectors for 1500.00 OEM remans and the labor was 700.00 in the Washington DC area.
My truck is new to me but has 400,000+ miles on it and runs great.
1967 Coronet R/T 1970 Coronet R/T 1997 Dakota 2006 Ram 3500 DRW
Page 1 of 3 1 2 3
