Engine Oil? weight? brand? engine size? #1776881
03/11/15 03:50 AM
03/11/15 03:50 AM
Albuquerque, New Mexico
moparmatt Offline OP
Just curious what everyone uses depending on big block small block or region of the U.S.? time of the year for you guys in midwest and up north.
Re: Engine Oil? weight? brand? engine size? [Re: moparmatt] #1776882
03/11/15 04:02 AM
03/11/15 04:02 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
10w 30 Valvoline VR1. Chicago SB, solid flat tappet
Re: Engine Oil? weight? brand? engine size? [Re: moparmatt] #1776883
03/11/15 11:21 AM
03/11/15 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Why would the engine size matter ???
Re: Engine Oil? weight? brand? engine size? [Re: JohnRR] #1776884
03/11/15 01:53 PM
03/11/15 01:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Exactly my thoughts, John. I would lean more toward engine usage.
Re: Engine Oil? weight? brand? engine size? [Re: MoparforLife] #1776885
03/11/15 02:10 PM
03/11/15 02:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
10w30 for me. I know some guys like 15w40 but that's too thick for me on cool fall days.
Re: Engine Oil? weight? brand? engine size? [Re: moparmatt] #1776886
03/11/15 03:06 PM
03/11/15 03:06 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I run Brad Penn 5w-30 in my 340 in temps from 45-95 degrees.
I have tried 15w-40 but it was too thick and it made the lifters tick at WOT and on cold startup. Then I tried 10w-30 and the WOT lifter tick was gone but then I still had some minor lifter ticking at cold startup. So then I tried the 5w-30 and I have been running it ever since with no lifter ticking problems except for the at the very first startup after it has been sitting all Winter long.
Re: Engine Oil? weight? brand? engine size? [Re: YO7_A66] #1776887
03/11/15 03:11 PM
03/11/15 03:11 PM
Georgia
Steve Bryant Offline
Georgia
The local engine shop suggested that the older engines will last longer by running Rotella T. I am running 15W40 where I live in Georgia in a 440 block used as a semi-regular driver.
Re: Engine Oil? weight? brand? engine size? [Re: Steve Bryant] #1776888
03/11/15 03:20 PM
03/11/15 03:20 PM
Tipp City, Ohio
Backfire Offline
Backfire  Offline
Tipp City, Ohio
I like to run 5w30 with plenty of zddp.
should be heavy enough if your bearing clearance is good and your oil temps aren't too high.
