'72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? #1776438
03/10/15 03:11 PM
03/10/15 03:11 PM
Rancho Cucamonga, CA
D_C Offline OP
D_C  Offline OP
For '72 - '80 Dodge Pickup, I am having a difficult time locating replacement Clutch & Brake Pedal Pads. I read an earlier post about Kenworth rubber pads being the same size.
As for now, the previous owner applied adhesive-backed antiskid sandpaper, but I would relly like to find correct replacements.
When I have looked in junkyards, I wind up finding Auto Trans trucks or that the ones I need are missing or already harvested.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776439
03/10/15 03:39 PM
03/10/15 03:39 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you tried the local parts store? Sometime the Dorman Help section will have replacements.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: stumpy] #1776440
03/10/15 04:47 PM
03/10/15 04:47 PM
D_C Offline OP
D_C  Offline OP
Yes, I have looked in all my local auto parts stores along with the Help Sections and Online at Dorman, JC Whitney, MOPAR Trucks.com, and general Google searches. I ordered them online, but then was informed that even though they advertised the parts for sale, they were no longer available and promptly cancelled my order.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776441
03/10/15 04:57 PM
03/10/15 04:57 PM
Grand Prairie,Texas
Grand Prairie,Texas
That pretty much sucks.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776442
03/10/15 10:01 PM
03/10/15 10:01 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
will the '69-'77 dodge van pedal pads fit? if so, i know where there are some for sale
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776443
03/10/15 10:19 PM
03/10/15 10:19 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776444
03/10/15 11:11 PM
03/10/15 11:11 PM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
1923 Buick pads fit like they were made for them. They just look different. You can get them from Rock Auto, part number CB13. Peterbilt pads are supposed to fit, too, but I can't confirm that. I think part number 06-00754 is what is supposed to fit. I'm actually considering re-shaping the metal plates to Chevy dimensions just so I can have nice reproduction parts any time I need them. Plus, I can get the stainless dress up kit for them. Try finding a set of those for a Dodge.
OIF V and OEF X veteran and proud of it!
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: Golden-Arm] #1776445
03/10/15 11:35 PM
03/10/15 11:35 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
No they are different. Did you call the dealership? They were the same up until 93.
LMC sells the auto brake but not the standard shift version.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: Hugh Jorgan] #1776446
03/11/15 03:57 PM
03/11/15 03:57 PM
D_C Offline OP
D_C  Offline OP
Thanks for all the replies. Also Thanks Chris/Jerseybud. I looked at the pair on EBay, might go with those, but they look pretty dirty and worn for $80 plus shipping.
Yes, I did try calling local Dodge Dealer Parts Departments and they said they looked it up in the system and that they were no longer available. Someone on Moparts said that around 5-years ago, you could still get them from Factory Dealers, but seems like not any more.
I'll bet there are some dusty on a shelf somewhere at some dealer in the country, but so far I haven't had any good luck.
This is what they look like at the moment. The previous owner covered them and the accelerator pedal with anti-skid stair tape.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776447
03/11/15 08:26 PM
03/11/15 08:26 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
$80??? keep looking
1981 Dodge D150 360 auto
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: basketcase] #1776448
03/12/15 04:42 AM
03/12/15 04:42 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What changed from 81-93? Why wont they work?
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: 76dodgeboy] #1776449
03/12/15 05:24 AM
03/12/15 05:24 AM
D_C Offline OP
D_C  Offline OP
Pretty sure they fit/work too, but even those were not available from Factory Dealerships, etc, as I have been looking. I asked my local dealership for 1993 pickup Clutch and Brake Pedal Pads and was told, No Longer available.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776450
03/12/15 10:28 AM
03/12/15 10:28 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
From the factory some of them have a coating that develops with age that comes off with elbow grease. You can see in his last pic where he removed it to show the part number in the rubber. That pair is on the dirty/old side of the realm, but the rubber is not affected.
Pads are the same thing from 72-93. Pretty sure they went NS1 about 2 years ago, about early 2012. They were all over ebay then evaporated.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: jerseybud] #1776451
03/13/15 01:51 AM
03/13/15 01:51 AM
ND
dodgedon Offline
dodgedon  Offline
ND
Collectors auto supply show 22 in stock and Silke's auto parts show 1 in stock.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: dodgedon] #1776452
03/13/15 05:10 AM
03/13/15 05:10 AM
D_C Offline OP
D_C  Offline OP
Thanks for the replies.
Collector's wants $45/each. The Used EBay ones are essentially $40/each.
Seems a bit much for parts that were likely $8 or $10 each just a few years ago.
I can continue to check my local junkyards and Pick A Part too. It works for now, but eventually I would like to get Factory Pads.
It is somewhat amazing to me that something this ordinary would be such a big problem. That, and windshield wiper blades for my '79 Jeep CJ5. Those too are now hard to come by or no longer available at autoparts stores.
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: D_C] #1776453
03/13/15 04:08 PM
03/13/15 04:08 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
make sure you put an ad in the parts wanted section here, never know who has some laying around...
Re: '72 - '80 Dodge Pickup Clutch & Brake Pedal Pads? [Re: basketcase] #1776454
03/14/15 03:02 PM
03/14/15 03:02 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
Let me look in the garage, pulled a set off a 1976 in a u pull it yard a few years back, They were near mint.
I just have to remember where I put them...
