replacing seat foam 71 challenger bucket seats #1775818
03/09/15 06:26 PM
03/09/15 06:26 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
I'm getting close in getting some new seat covers on my 71 bucket seats. the covers are fairly worn and I can seen the foam peaking through the seats in a few places. should I get new foam when I recover these seats? will it be a noticeable difference in comfort with new covers compared the old foam with new covers? should I buy anything else when I get the new seat covers?
I saw dante was having a group buy so I'm trying to get in on that before this Friday.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: replacing seat foam 71 challenger bucket seats [Re: Jerry] #1775819
03/09/15 06:29 PM
03/09/15 06:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I always suggest new foam for the bucket seats to my clients. The old foam shrinks over time, plus it eliminates any damage & funky smells.
For the best fit of your new covers, go with new foam.
Other things to consider if you want to get it all at once;
Seat latches & shims.
Bump stops.
Plastic seat backs.
Rear seat divider panel.
With the seats out, it is also a great time for new carpet if needed.
Re: replacing seat foam 71 challenger bucket seats [Re: Alaskan_TA] #1775820
03/09/15 06:40 PM
03/09/15 06:40 PM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
yeah I'm doing carpet. seat backs are in pretty good shape. i'll take a look at the knobs etc.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: replacing seat foam 71 challenger bucket seats [Re: Jerry] #1775821
03/09/15 08:22 PM
03/09/15 08:22 PM
Georgia
Steve Bryant Offline
Georgia
If I had to do it again, I would replace all the foam. How many times have you heard someone say "I wish I had just stuck with my old foam" ?
A few months ago, I recovered the buckets in my 70 Barracuda and I replaced only the driver's foam. The passenger foam seemed to be in good shape so I did not replace them.
Now, several months later I am not sure why I didn't replace all the foam. The seats all look great but the passenger's foam is less dense so the passengers sit a couple of inches lower now. Also, the 40-year-old foam felt to be in good shape but the plastic was ripped and so they did have some slight odor to them and I had to baby the fabric when I recovered them.
Re: replacing seat foam 71 challenger bucket seats [Re: Steve Bryant] #1775822
03/09/15 09:38 PM
03/09/15 09:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
New foam can be a pain from my experiences. I only replace it when I have no choice. If you use good quality covers, then you can make them fit tight on the used foam.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: replacing seat foam 71 challenger bucket seats [Re: Jerry] #1775823
03/09/15 11:10 PM
03/09/15 11:10 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
The foam in my 69 Bee was deteriorating and falling out in little pieces. The seats were saging. I bought new foam and had it replaced. The guy that did the work repaired the springs while he had the seats apart. My seats now set and feel like new. Spend the extra cash and get the new foam. You won't be sorry you did.
Re: replacing seat foam 71 challenger bucket seats [Re: Dabee] #1775824
03/10/15 11:29 AM
03/10/15 11:29 AM
P
PasiR Offline
PasiR  Offline
P
Best source for new foams?
Re: replacing seat foam 71 challenger bucket seats [Re: PasiR] #1775825
03/10/15 11:45 AM
03/10/15 11:45 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
they are on sale at dante's right now with the moparts group buy.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: replacing seat foam 71 challenger bucket seats [Re: Jerry] #1775826
03/10/15 11:46 AM
03/10/15 11:46 AM
pa.
dan9 Offline
dan9  Offline
pa.
Be sure that you have the correct seats before ordering anything. Later seats look the same until you get the covering off. I think 72 has similar backs but lack springs. Also make sure you get the correct foam for the upholstery. I found the headrest area is probably the toughest area to get right, it gets pretty tight but it will go. Follow Lengendary's videos especially about marking centers and what to attach first and you should be good. That foam you are seeing may be what is in the upholstery itself. If mine were in good shape, didn't smell and matched the upholstery I would consider using the old ones but the new foam does fit great and is relatively cheap.
