Re: Need help finishing off inside of enclosed car trailer
[Re: Bigbeep]
#177576
12/30/08 09:46 AM
12/30/08 09:46 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
What did you use for trim on the floor, ceiling and top of carpet?
I reused the trim at bottom of wall/floor transition. Top of carpet I bought trim at home depot in the flooring dept. where I got the linoleum.
Do you glue the carpet on? If so, did you just use liquid nails?
Yes it is carpet glue that comes in 2-3gal buckets. Apply glue to area with notched trowel, then I would stick the carpet on and staple the top edge to prevent any movement while glue sets up. Apply trim.
[Re: StrokedW7]
#177577
12/30/08 09:53 AM
12/30/08 09:53 AM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I aslo wondered if there wouldnt be some paint that I could use on the floors that would work or what about something like Rhino lining? Just thinking out loud.
Steve
I work for Rhino Linings and it is a bare to clean on an old floor if you have a oil leak. I personally would use the garage floor coating from Home Depot or U Coat It.
[Re: 65 Hemi]
#177578
12/30/08 10:28 AM
12/30/08 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Steve
This was the reason I put the diamond plate down on the floor, you dont have to worry if the paint will stick and also the plate is easy to clean even if you had a oil leak(blown engine)
[Re: MR_P_BODY]
#177579
12/30/08 11:04 AM
12/30/08 11:04 AM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Steve...whats up?? Whats with the trailer? Are you actually going to take the car somewhere to race it??
[Re: B3422W5]
#177580
12/30/08 05:21 PM
12/30/08 05:21 PM
Posts: 2,333 Kalamazoo, MI
StrokedW7
Kalamazoo, MI
Steve...whats up??
Hey... No comments from the peanut gallery!!!
Hope things are going well and... congrats on engagment.
Steve
[Re: MegaDart]
#177581
12/30/08 10:25 PM
12/30/08 10:25 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I put some pics of mine... I ordered it with cabinets/work bench,,floor treatment,,and wall/ceiling covering... I like the flooring,,,kinda marble like stuff,,linoliem ?,,,wipes up easy,,, I have since put down some more diamond plating running into the trailer,,,for the tires so they dont chew up the flooring ,,, Also put in a S4000 winch,,and a I-Home(25$) on ebay,,,so i can hear the announcer,,,and play my ipod...
[Re: 69CHARGERMD]
#177582
12/31/08 02:27 AM
12/31/08 02:27 AM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
Looks like 69Charger and I have similar tastes. I too have a Warn S4000 winch, but I went ghetto with the old boombox. Anyway here is my new one.. My old trailer I carpeted the inside floors. Actually I think I prefer the carpet to the linoleum I currently have. I was going to go with rubber coin but have a couple of buddies who have had it come up. On my wood floor I used some Home Depot trim on the bottom and for any entry point we simply used some aluminum angle.
