Got a 68-70 B with 440, RPM Intake and Holley? Read On
#1775585
03/09/15 02:44 PM
03/09/15 02:44 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Man! Tight squeeze! Looks like I might have an inch or so to the hood frame from the top of the choke box. Yikes! What are using for an air cleaner? I was going for an airbox type fresh air plenum but now I'm thinking I'd better get a 2" drop with a K&N filter lid. I asked the question last summer when the engine was out and I could only guess what space I'd have but now it's go time!
Re: Got a 68-70 B with 440, RPM Intake and Holley? Read On
[Re: Mr.Yuck]
#1775587
03/09/15 03:34 PM
03/09/15 03:34 PM
Posts: 166 Massachusetts
Row_your_own
Massachusetts
I ran same combo in a Dart several years back, I used this...
1968 Road Runner 383 4-speed Factory BB1 black on black
[Re: Big Bad Bee]
#1775589
03/09/15 03:55 PM
03/09/15 03:55 PM
Posts: 52 Texas
shart70rt
Texas
I have a drop base with the foam lid. Both are new, tried to get them to work with a very tall single plane couple of years ago but was too tight. Ended up switching to a dual plane dual carb setup, and it came with a filter. These have been sitting on the shelf since then. $50 plus freight.
Stephen PM me here
70 Go Mango Charger RT White Vinyl Top 18 Spline 4 speed Lakewood Scatter Shield/ Centerforce DF Clutch, Hydraulic bearing 505 Stroker, dual 600's, hyd roller cam - 525 hp, 640 torque
[Re: Big Bad Bee]
#1775590
03/09/15 04:08 PM
03/09/15 04:08 PM
Posts: 52 Texas
shart70rt
Texas
you can also gain a little more clearance by putting spacers between the k member and frame. Dont want to drop it too much or you can have ground clearance problems, or steering component clearance problems.
[Re: shart70rt]
#1775591
03/09/15 04:23 PM
03/09/15 04:23 PM
Posts: 75,046 U.S.S.A.
JohnRR
U.S.S.A.
there won't really be a ground clearance problem , the K frame and components bolted directly to it will not get closer to the ground , but you will put a side/bending load on the end of the torsion at the rear Xmember
[Re: Big Bad Bee]
#1775595
03/09/15 07:38 PM
03/09/15 07:38 PM
JohnRR
U.S.S.A.
Lose the choke and choke tower , the filter lid doesn't work for bleep if it's pressed up against the underside of the hood.
Another reason I prefer low decks , you get an extra 3/4" clearance ...
I was wondering who the first person would be to recommend milling off the choke tower. You win, John. It's a last resort. Don't want to mess up a good Avenger if I don't have to and I would REALLY like a choke. I really wanted to build a 451 stroker but this 440 presented itself as a less expensive alternative. Plus it looks awesome.
is there such a thing as a good running avenger ?
Does proform make a main body for the avenger series ?
[Re: Big Bad Bee]
#1775601
03/11/15 08:49 PM
03/11/15 08:49 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
68 Charger, 440, RPM, Mighty demon carb. Hood clearance same as what you show in those pics. Wasnt any better with an edelbrock 1407 I used to run. I use a stock 68 unsilenced air cleaner. Due to the odd diameter of the stock mopar lid, the usual suspects for drop base won't work. I had to buy a complete ford motorsports air cleaner on ebag. I just used the drop base from it. plenty of clearance now. this was years ago and maybe someone has come up with a drop base thats the right diameter. As an aside, I ran a holley projection for a while and that TB was definitely shorter than a normal carb. I was able to run the standard base that came with the unsilenced.
[Re: dogdays]
#1775604
03/12/15 12:38 AM
03/12/15 12:38 AM
Big Bad Bee
Spokane Valley, WA
Dogdays, thanks for the positive input. I respect JohnRR's knowledge and opinion, although I must say that if I did everything he told me I should do, I would have $50K involved in my car and it would be bulletproof. DKN 1997, Rarefish and 383man, are any of you running a holley with choke tower? If so, how's the performance with that drop air cleaner? Since we are going there, have any of you removed a choke tower? if so, what did you use?
I’m listening.
