A few pics and results with Frankenstein part 2
#1775338
03/09/15 11:59 AM
03/09/15 11:59 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Started the new 540 on pump gas and ran it up to 200 degrees a few times, then I out on one of my customer new ProSystems pump gas nitrous carb to make the first pass to seat the rings before switching over to Methanol.
First pass it ran a 9.58 at 140 and the water temp got up to 220...(I always pull into the water box at 160) so the carb was too lean but didn't lay over. And then I switched over to the methanol carb.
Well not the results I was expecting. It ran 9.58 when all the intake valves were hitting the Pistons and then blew up Frankenstein 1 so I figured going from a 528 to 540 and the valves not hitting the Pistons it could run a high 9.30 but it must be waaaay lean on the methanol carb because it left harder but was quite a bit slower all the rest of the way down the track as you can see. But about the same MPH. 9.64 at 140
I only had time to make 2 passes so I'll do some tuning on the carb next weekend.
Even with the methanol it got up to 200 so it was pretty lean too.
Picked the wheels up quite a bit more on methanol.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: A few pics and results with Frankenstein part 2
[Re: WadeMetzinger]
#1775341
03/09/15 05:33 PM
03/09/15 05:33 PM
Posts: 10,184 A Red State
SNK-EYZ
A Red State
Just wondering, What's the normal expected amount of heat/temperature rise you should expect from waterbox to end of pass (when you turn on the return road)?
[Re: SNK-EYZ]
#1775342
03/09/15 05:53 PM
03/09/15 05:53 PM
Posts: 5,115 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Methanol always added a lot of torque for me. Get the jetting right and I doubt it runs over 180-185. The stat will also help burn off condensation in the motor and prevent milky oil. I had to start running a T-stat to ever reach a 160 temp under normal racing conditions. (dirt car) ![](/ubbthreads/images/graemlins/Twocents.gif)
...FAFO...
[Re: WadeMetzinger]
#1775344
03/09/15 11:54 PM
03/09/15 11:54 PM
skicker
"The Champ"
"The Champ"
Western Md.
When do you drain your fuel bowls? I used to drain mine when the night was over and fill with race gas then. Start it at the shop to warm it up and check everything over 3 or 4 hours before race time. Race and then repeat... ![](/ubbthreads/images/graemlins/thumbs.gif)
...FAFO...
[Re: WadeMetzinger]
#1775346
03/15/15 02:47 AM
03/15/15 02:47 AM
WadeMetzinger
Tulsa, Ok
Drilled out some new/bigger jets and went to the track today, no where near the weather we had last week, lots of moisture in the air from rain Friday and Saturday morning.
But it picked up a tenth, still a little lean.
I think it has a 9.38 in it with a little more jet, better weather and fresher track (I made it to Test-n-Tune 15 min before they closed so the track was going away), but I did get 3 passes in 15 min, well I ran out of methanol on the last one but got a reaction time and 60' time.
[Re: WadeMetzinger]
#1797346
04/07/15 01:31 PM
04/07/15 01:31 PM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Sounds like you're making real good power Wade!!
