more than just the torsion bar moving backwards #1774931
03/08/15 08:21 PM
03/08/15 08:21 PM
British Columbia
Y
yellowgtx Offline OP
Y
British Columbia
I have removed torsion bars before and have a tool for them. But now I am trying to remove them from my 65 Plymouth Satellite. The left side one started to move with the 1st hit. The trouble is the hex part where the front of the torsion bar goes in is coming out as well and still has torsion bar in it firmly. Any ideas how to stop that from moving?
After almost 71 years I am on my last car. A 65 Plymouth Satellite straight axle altered wheel base car.
Re: more than just the torsion bar moving backwards [Re: yellowgtx] #1774932
03/08/15 08:29 PM
03/08/15 08:29 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Is the whole lca moving? or just the hex? Sounds like your lca bushing has separated from the shaft and the entire arm is pulling back with the bar-
Re: more than just the torsion bar moving backwards [Re: Pynzo] #1774933
03/08/15 09:14 PM
03/08/15 09:14 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You should be able to hold the bar with one hand and rattle the LCA forward by hitting it with a hammer.
Sheldon
Re: more than just the torsion bar moving backwards [Re: yellowgtx] #1774934
03/08/15 09:25 PM
03/08/15 09:25 PM
As said just tap the LCA forward with a brass drift/hammer. I'm assuming the wheel is off & the drum/caliper off is even better to make the assy as light as possible. Put a hyd jack under the LCA & support it just enough so you have more of a straight horizontle line/less weight binding the assy
Re: more than just the torsion bar moving backwards [Re: RUNCHARGER] #1774935
03/08/15 09:33 PM
03/08/15 09:33 PM
British Columbia
Y
Y
British Columbia
How easy Soak with Penetrating oil and go away for the weekend. Just went out to see if LCA or Hex anchor was moving. Tapped T bar tool back Tapped the LCA forward and T bar stayed back. did it Once more and T bar was out. Getting too old, Memory getting bad. The other times everything was still connected solid as was dropping the whole unit with the K frame when I removed T bars.
Re: more than just the torsion bar moving backwards [Re: yellowgtx] #1774936
03/08/15 10:50 PM
03/08/15 10:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Have you got EVERYTHING disconnected so the LCA is hanging freely? Shock,lower ball joint, tie rod end, etc.. With the LCA just hanging there the torsion bars should almost just slide out if they aren't rusted in.
