Page 2 of 3 1 2 3
Re: Cummings Powered, what years to avoid [Re: Copper Dart] #1774691
03/10/15 12:24 AM
03/10/15 12:24 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I don't know how it is in FL but here you have to practically give it away if it's a 2wd. Good for buying, horrible for selling.
Re: Cummings Powered, what years to avoid [Re: cudaman1969] #1774692
03/10/15 12:30 AM
03/10/15 12:30 AM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
I have 2 Cummins powered Dodges that I have put hundreds of thousands miles on. Mostly loaded down with a large camper and towing a 28 ft triple axle enclosed race car trailer.
My first one is a 92 club cab dually it is a custom conversion and has crew cab doors and club cab.The worst thing about it was the Getrag trans it blew apart. Truck was a little low on power but it would still get up to 70 and tow. 1st gen trucks also have a wider turning radius.
My second truck is a 97 club cab I have hot rodded it ported head, bigger turbo, camshaft, 4000 rpm gsk, different inter cooler. The worst part of it was the nv4500 trans 5th gear comes loose and tore it up. I put the NV5600 trans and a dual disc clutch in it now it is bullet proof. This was an easy bolt in with factory parts. The NV4500 I rebuilt with the 5th gear fix and it is in the 92. This truck fully loaded with trailer will accellerate up an 8% grade.
I like things mechanical. I would never buy a truck run by electronics.
Real Men shift for themselves
Re: Cummings Powered, what years to avoid [Re: 1DGEMAN] #1774693
03/10/15 01:06 AM
03/10/15 01:06 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The only trans I haven't had the pleasure of driving, or destroying is the NV5600. I will have to give one my torture test soon! Wasted 5, yes FIVE NV4500's in a 99 2WD dually, 2 G56's in an 07, 3 48RE's in an 04, and just 1 auto trans in my 96. Haven't lunched the trans in my 93 club cab ramp truck yet, and managed to keep my 92 dually auto trans right on going though it was like riding on a buckboard! Anyone have any luck with the AISIN trans?
JB Rhinehart, Realist
A-Body's RULE!
Re: Cummings Powered, what years to avoid [Re: Rhinodart] #1774694
03/10/15 02:06 AM
03/10/15 02:06 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
I bought a brand new 93 4x4 W250 singe cab with an auto. I had it in for 3 new transmissions, converters, and flex plates , 19 times in the first 2 years. I hired a lemon law layer.
Ma sold me a new 96 loaded club cab with a 5 speed for around 10k on a 30kish sticker.
I towed a 20k lb dozer around with it, along with other heavy loads for 429k miles, when I sold it. In that time, I replaced one clutch, along with front suspension pieces.I mostly sold it because of rust issues.I sold it to a guy I know who does body work.
I seen him at the bank about 6 months ago,in the truck. He said its still running great with over 500k.
Best truck I ever owned.
Keep the oil and fuel filter clean is my advice.
Re: Cummings Powered, what years to avoid [Re: Rhinodart] #1774695
03/10/15 01:06 PM
03/10/15 01:06 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Try the NV5600; I doubt even YOU could break one. Oooh and get a Southbend Clutch from Peter too.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Cummings Powered, what years to avoid [Re: DaytonaTurbo] #1774696
03/10/15 01:18 PM
03/10/15 01:18 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Nobody around here wants a 2wd diesel. You can find some really nice trucks for cheap b/c they are 2wd. My '01 is 4x4...I don't like getting stuck on wet grass.
I like my '01 quadcab 4x4 cummins auto. Pulls good, but desperately needs a tighter converter. That and the fact that it isn't a crewcab are my only gripes about it. Once you take care of a couple quirks they have they're good trucks. Get a good lift pump, fuel pressure gauge, rebuild the front suspension, and add a steering box brace.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cummings Powered, what years to avoid [Re: DPelletier] #1774697
03/10/15 01:23 PM
03/10/15 01:23 PM
DPelletier Offline
DPelletier  Offline
The 2003 offers the following;
- common rail cures the VP44 failure issue
- no post injection event, no catalytic converter
- available NV5600 6spd
- good brakes and steering
- superior quad cab with rear seating for adults.
it doesn't have;
- plastic intercooler tanks
- TIPM totally integrated power module....so you have to spend $1,200 to fix a burnt out headlight
- urea injection
- variable geometry turbos...another complexity that you don't need, expecially when they get all sooted up due to the exhaust gas recirc.
- dual mass flywheels....just a crappy idea all way around.
- catalytic converters that need to periodically regenerate and get hot enough to rival the surface temperatures of a white dwarf star.
....I have several diesel trucks, many gas trucks and I've owned dozens more that I've sold off or traded in. I could buy or drive any truck I like but my 2003 is the oldest and best in my small fleet....I truly think that due largely to environmental regulations that the newer diesels are fraught with issues....it isn't Dodge's or Cummins' fault...they still make the best diesel truck out there but they are getting far too complicated for me to consider keeping one past the warranty period.
My 2003 has a 4" exhaust, Southbend ConOFE clutch and a Smarty reprogrammer. No issues other than common wear issues in 12 years. Truck has gotten a high of 20.5mpg and averages 16mpg in mixed driving...and it's an 8338 lbs, dually, 4x4 quad cab. Output is dependant on the programmer....between the stock 305/555 to over 400 hp and almost 800 ft lbs of torque. I tow regularly at a GCWR of 20,000 + lbs.
My "runner up award" goes to a 2001.5 ETC/DEE HO 6spd ram with the rear disk brakes....even with having to keep an eye on the VP44 and dealing with the vague 2nd Gen steering, this is an awesome truck.
Re: Cummings Powered, what years to avoid [Re: DPelletier] #1774698
03/10/15 02:56 PM
03/10/15 02:56 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I am starting to look for another truck, might just have to do an NV5600 this time. As far as SB clutches are concerned, NEVER AGAIN! I blew a clutch on the 07 while at the Mopar Nats, found a shop very close and overnighted an assembly from SB to Columbus, OH. It had issues from the get-go. Even took the truck TO the SB Clutch plant in South Bend and they told me it was normal. It didn't last long after that.
A-Body's RULE!
Re: Cummings Powered, what years to avoid [Re: DPelletier] #1774699
03/10/15 03:07 PM
03/10/15 03:07 PM
CA
crackedback Offline
crackedback  Offline
CA
Had a few trucks and whenever they needed a clutch, I call Peter at South Bend. Never an issue with any of them. Any that have a dual mass flywheel get a solid piece. Some of the best money I've spent on driveline parts.
Re: Cummings Powered, what years to avoid [Re: Rhinodart] #1774700
03/10/15 03:49 PM
03/10/15 03:49 PM
DPelletier Offline
DPelletier  Offline
Which one did you go with? I've had several ConOFE's and never a problem....even at full hp levels.
...starting to think it might all just be you....
J/K
Re: Cummings Powered, what years to avoid [Re: crackedback] #1774701
03/10/15 03:50 PM
03/10/15 03:50 PM
DPelletier Offline
DPelletier  Offline
My one G56 truck now sports a proper one pce flywheel and a Southbend clutch.
Re: Cummings Powered, what years to avoid [Re: DPelletier] #1774702
03/10/15 07:36 PM
03/10/15 07:36 PM
West Palm Beach, Florida
Copper Dart Offline OP
http://miami.craigslist.org/pbc/cto/4832655487.html
I'm not sure I really need a dually so I'm considering this one..
Wondering how much it would cost to fix third gear?
Thanks for the Super answers guy's..
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Cummings Powered, what years to avoid [Re: Copper Dart] #1774703
03/10/15 08:37 PM
03/10/15 08:37 PM
Manitoba, Canada
Manitoba, Canada
Smoker vents on the windows? If 3rd is grinding at 149k miles, 30k after a rebuild makes me wonder what's going on inside.
Are you capable of rebuilding a transmission yourself? If not, expect to crap out a few grand to have someone do it for you.
Re: Cummings Powered, what years to avoid [Re: DaytonaTurbo] #1774704
03/10/15 09:28 PM
03/10/15 09:28 PM
STL
cdstl Offline
cdstl  Offline
STL
The NV5600 weighs the better part of 500 pounds. A Mopar guy that does these transmissions locally uses an electric fork lift to get them out.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Cummings Powered, what years to avoid [Re: cdstl] #1774705
03/10/15 09:55 PM
03/10/15 09:55 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The truck listed has an NV4500 5 speed. 3rd gear grinding is common. The problem is likely a worn-out blocker ring not the gear itself. The blocker ring is cheap but you will have to remove the mainshaft from the trans to replace it. I fix them all of time.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Cummings Powered, what years to avoid [Re: cdstl] #1774706
03/10/15 09:55 PM
03/10/15 09:55 PM
DPelletier Offline
DPelletier  Offline
That 2001 is a standard output with a 5spd, NV4500.
Re: Cummings Powered, what years to avoid [Re: DPelletier] #1774707
03/11/15 12:06 AM
03/11/15 12:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I find it hard t believe some people kill the 4500 trans when I've been towing close to 20K lbs for nearly 20 years with the same one????????????? Yes I've had 5th gear come loose but didn't damage anything.
Doug
Re: Cummings Powered, what years to avoid [Re: Copper Dart] #1774708
03/11/15 12:21 AM
03/11/15 12:21 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
That truck ain't from around here (looks to have MN plates). Look it over real good for rust issues...
Re: Cummings Powered, what years to avoid [Re: SomeCarGuy] #1774709
03/11/15 12:33 AM
03/11/15 12:33 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Not sure what guys are doing to say all the auto trans are junk. I know of at least three off the top of my head that went over 200k without a rebuild, two pulling cars, one was loaded with tools at grossed about 8k all the time. The two oulling cars were turned up. Not 500 hp, but more than stock. 1st gens.
The trans usually dies for lack of professional maintenance. I say pro because even swapping fluid and filter is not quite enough, bands need adjusted and it don't hurt to turn up the line pressure a tad as the spring loses tension over the years.
Re: Cummings Powered, what years to avoid [Re: Fat_Mike] #1774710
03/11/15 10:07 AM
03/11/15 10:07 AM
Yes it's been there but as a 2wd, he never used it in the snow/salt environment (he said).
I'm not looking for a show piece and a good look at the undercarriage will show if it was regularly exposed to a salted road. I think it's still factory paint.
I do have a lift and heavy duty trans jack but lack the refined skills to feel comfortable in rebuilding the transmission myself. He said the transmission shop that did the rebuild had a good reputation and he is very surprised it's giving him this trouble.
Options? A salvage trans with warranty? Up grade to what? Try and fix it myself?
They did install a new clutch and friends during the visit too.
71Yelladustr, how difficult is the fix? Special tools? You visiting south Florida any time soon?
Copper
Mom.
Ricky Valdes
Page 2 of 3 1 2 3
