Rear end yoke torque specs. #1774627
03/08/15 03:15 AM
03/08/15 03:15 AM
r.i.
stuman Offline OP
stuman  Offline OP
r.i.
Was wondering what the torque spec where on a 69 Dana. Also is there a gasket between the yoke and the seal? thanks
Re: Rear end yoke torque specs. [Re: stuman] #1774628
03/08/15 04:08 AM
03/08/15 04:08 AM
I'll look in the FSM in the morning, I'm almost positive the pinion nut torque is 150 Lbs, no gasket between the yoke and the seal, the seal rides on the yoke sealing it up
Re: Rear end yoke torque specs. [Re: stuman] #1774629
03/08/15 04:39 AM
03/08/15 04:39 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pinion nut torque is 250-270 ft. lbs.
