Gen 3 max effort hp? #1774026
03/07/15 09:46 AM
03/07/15 09:46 AM
gregsdart Offline OP
OK, this is a fun post for those guys stuck inside, and insomniacs like me. If you were to tackle a stroker Gen 3 motor for high hp brackets, what do you think it would make for power? Lets say we go with 426 cubes, 14.5 + compression, best available valvetrain, custom tunnelram, dual Dominators or Termintors with alky, (your choice),vacuum pump, the usual stuff for close to the best that can be built. I am assuming a large bore aluminum Mopar block, or at least a 4.090 bore. Opinions?
Re: Gen 3 max effort hp? [Re: gregsdart] #1774027
03/07/15 03:28 PM
03/07/15 03:28 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Aluminum block large bore 3.79 stroke Thitek heads.
Spine the thing to 9000 rpm and I believe 1000 hp will be obtainable.
Dave Barton has gone 148 in his 3300 lbs challenger which is 888.88 hp
Matt
Re: Gen 3 max effort hp? [Re: gregsdart] #1774028
03/07/15 03:52 PM
03/07/15 03:52 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
And which pieces will live at that hp level? I'm contemplating the switch from BB to gen 3 and checking CL for core engines. Stock block ok? Which core engines to avoid, if any?
Re: Gen 3 max effort hp? [Re: 451Cuda] #1774029
03/07/15 05:51 PM
03/07/15 05:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Stock blocks are fine N/A aspirated. I know Bartons tach hit 88-8900 in one of his in car videos. Im guessing he has Jesel keyway lifters and rockers. That is probably $5000 alone. But if the engine peaks in the 7000 rpm range, stock rockers and lifters have proven to live just fine.
Mopar to the bone!!!
Re: Gen 3 max effort hp? [Re: 72Swinger] #1774030
03/08/15 12:17 PM
03/08/15 12:17 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I've heard differently about the rockers. HS is what I've heard he runs
Be nice to know what he runs.
Matt
Re: Gen 3 max effort hp? [Re: MattW] #1774031
03/08/15 12:52 PM
03/08/15 12:52 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Barton worked with T&D for his gen II rocker system. They may have used HS until T&D came out with theirs.
Re: Gen 3 max effort hp? [Re: fbs63] #1774032
03/08/15 03:42 PM
03/08/15 03:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Digby's Dart or the Goss Challenger are just two examples of late model Hemi getting it done.
This site will never be a Gen 3 tech hot bed. You need to move to other sites with a younger group of guys. This place Is stuck in the past.
Challengertalk.com is one.
Re: Gen 3 max effort hp? [Re: MattW] #1774033
03/08/15 03:53 PM
03/08/15 03:53 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I agree with Matt, Max effort, money no object, dropping a blank cheque off at RBRE and telling him to go nuts I think you could get 1000 hp, but it would be very high strung. What do you guys think the max HP for a low maintenance Gen III would be? I guess it's dependant on RPM and not HP, so really what's the max RPM a Gen III could live at without having to replace valve springs on a regular basis, 7500 ish?
Re: Gen 3 max effort hp? [Re: WO23Coronet] #1774034
03/08/15 04:16 PM
03/08/15 04:16 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Barton is using stock gutted lifters and Harland Sharp rockers.
He is not a fan at all of the T&D or jesel stuff
Re: Gen 3 max effort hp? [Re: FastmOp] #1774035
03/08/15 05:43 PM
03/08/15 05:43 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Digby give up on the predator headed engine??
Re: Gen 3 max effort hp? [Re: GTS340] #1774036
03/08/15 06:17 PM
03/08/15 06:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Nope. I forgot he's predator heads. Sorry!
The Goss Challenger might not be either. I'm getting old
Re: Gen 3 max effort hp? [Re: FastmOp] #1774037
03/08/15 07:41 PM
03/08/15 07:41 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I contacted Barton last week about buying Harland Sharpe rocker for my build. He gave a very long reply. The Harland Sharpe rocker he uses are done to his specs or design. He informed me that it takes a lot of machining to get them on. Offered to do my heads for them at one thousand dollars, or would tell me how to do it. Told me the T&D required way less work and did not say anything about not recommending them. Of Course I do not know what he does to alter them from production to meet his requirements and have never had a set of production to try on a head. Other people seem to be running them and not talking about having to do mods.
Re: Gen 3 max effort hp? [Re: FastmOp] #1774038
03/08/15 10:43 PM
03/08/15 10:43 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Goss Challenger is G3 BES power
Re: Gen 3 max effort hp? [Re: 451Cuda] #1774039
03/08/15 11:14 PM
03/08/15 11:14 PM
IL
knyech1 Offline
knyech1  Offline
IL
5.7 and 6.1 blocks have thin cylinder walls. Have seen them crack at as "little" as 750hp. Most guys want to throw a block away if they have to bore it any more than .020". The LX guys really spend A LOT of time and money tuning them to perfection to get them to hold up under higher hp. A 6.4 block is the most durable of the three. Getting your hands on one is tough right now though.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
