Retrofit roller lifters? (Oops...)
#177367
12/28/08 08:18 PM
12/28/08 08:18 PM
Posts: 234 SW FL
dodgedartgt
SW FL
When I originally posted, I typed roller rockers... What I meant and would like to learn about is roller lifters, SO...
Can someone tell me about retro fitting roller lifters into a '76 vintage LA block? Brands, prices, modifications necessary, anything else you can think of. TIA, Mike
Re: Retrofit roller rockers?
[Re: MoparforLife]
#177371
12/29/08 04:45 PM
12/29/08 04:45 PM
Posts: 3,577 Long Island, NY USA
BergmanAutoCraft
Long Island, NY USA
WHy do you want roller rockers??? They will give you no HP advantage over a set of dictile iron. The only advantage that they will have over the stamped OEM rockers is truer ratio. Here by Dulcich.
Some of us like reving our engines over 5K, and besides, lightening the valvetrain is ALWAYS a good idea.
[Re: BergmanAutoCraft]
#177372
12/29/08 07:10 PM
12/29/08 07:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Rollers ain't the answer for that. Better places to spend the money than that if that is the reason you are looking at. I don't like picking little needles out of the engine either.
I made a typo when I posted this originally... What I meant was retrofit roller lifters... sorry and thanx.
Roller cam is a completely different story.
[Re: MoparforLife]
#177373
12/29/08 08:17 PM
12/29/08 08:17 PM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
Not roller cam. You're thinking about roller cam bearings. To retrofit for roller lifters you need to bush the lifter bores. The sleeves will still end up being .904. You will need to find a shop with a special cam tunnel fixture for LA. They need to use this fixture to bush the bores, it needs to be LA specific. The closest shop I found was 100 + miles away. I was debating sending the block to Hughes before I found them.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
[Re: go-fish]
#177374
12/29/08 08:46 PM
12/29/08 08:46 PM
MoparforLife
Upper Midwest
Wrong answer! Been in this game long enough to know that a hydraulic roller cam is the terminology used to describe a camshaft ground to use a hydraulic roller lifters. Not referring to a camshaft using roller cam bearings
[Re: dezduster]
#177379
12/30/08 12:34 PM
12/30/08 12:34 PM
Posts: 13,616 md
mopars4ever
md
I did have to have a custom smaller base roller cam made up so the lifter oil grooves would not be exposed at max lift.
Is this a problem on all early pre roller blocks?
[Re: mopars4ever]
#177381
12/30/08 06:09 PM
12/30/08 06:09 PM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Depends on the block and how high a lift the cam has. On my '71 340 block the top of the lifer bores had a chamfer machined into them and that caused the oil groove to be exposed. But the machining was not consistent. Some sealed really well and others did not. Brian at IMM (user ou812) had a cam ground for me that solved the problem. Was about the same price as an off the shelf retrofit roller cam.
Re: Retrofit roller lifters?
[Re: dodgedartgt]
#177382
12/31/08 12:16 AM
12/31/08 12:16 AM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Waht year did the 318/5.2 & 360/5.9 become roller lifter blocks? Also... BUMP! Thanks, Mike
They started showing up ready for a roller in late '84 even though many still used flat tappets until '87-88.
[Re: mike_vango]
#177385
01/01/09 05:24 PM
01/01/09 05:24 PM
69Cuda340S
MARYLAND
For the cost and trouble of converting to a roller cam, you would be nuts if you didn't just find a later stock roller cam block.
i agree!!
A lot cheaper that way too.
