Re: Thumper Carbs?
[Re: Thumperdart]
#1771248
03/17/15 02:06 AM
03/17/15 02:06 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
110 sunoco and 12.5 compression. Keep in mind i had dist issues so first run was 9:30 and three bad runs and last one was a good one for how hot it was. My next TNT will be MATS in two weeks so trying to sort out anything i can before.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Thumper Carbs?
[Re: mikeysmopars]
#1771249
03/17/15 02:39 AM
03/17/15 02:39 AM
Thumperdart
State of confusion
Heard great things about the C12 fuel from Mark Monte and others so who knows there. What were the afrs from the start and through the midrange.
Re: Thumper Carbs?
[Re: Thumperdart]
#1771250
03/17/15 03:21 AM
03/17/15 03:21 AM
mikeysmopars
fresno ca
Only really got to see the last run and held from 12 to 13 after i shifted to second and high gear. My Buddie was able to turn the gopro off and on from his phone and download it but couldnt zoom in on it on the first few runs but was in the green digital lights the whole time. I need to mount it closer to the gauge to really read it. Still it never ran that good in the heat so it was encouraging ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Thumper Carbs?
[Re: mikeysmopars]
#1771251
03/17/15 03:39 AM
03/17/15 03:39 AM
Thumperdart
State of confusion
There's more there for sure but good runs. In thr green is not enuff info so see what's needed to see the gauge and can you post plug pics?
Re: Thumper Carbs?
[Re: Thumperdart]
#1771255
03/17/15 02:01 PM
03/17/15 02:01 PM
mikeysmopars
fresno ca
after last run in 90 degree heat
Re: Thumper Carbs?
[Re: Thumperdart]
#1771257
03/20/15 09:19 PM
03/20/15 09:19 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
![](/ubbthreads/images/graemlins/boogie.gif) Got my fuel filter today, installed it, put fuel in the cell,,fired right up!!! About 3-4 minutes of warming up, I could get out of car and check the timing, as I had the distributor out priming the new oil through the motor after oil change. I reset the timing to 35* as it was at 40* from my priming and replacing,etc. Let it warm up to 190* and adjusted idle RPM. Gave the idle air screws about 1/8 turn out and all was good. Sounds VERY clean and CRISP at idle and revs quickly. The Township went by today with their sweeper getting the cinders off the road, SO, I'm thinking they know I'm getting ready to roll here!! THANKS Dom!! ![](/ubbthreads/images/graemlins/thumbs.gif)
If you like drag racing, support your local track.
Re: Thumper Carbs?
[Re: mikeysmopars]
#1771259
03/21/15 03:08 AM
03/21/15 03:08 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
There is nothing to see mixture wise on that plug. The only thing the threads and strap tell you is heat. The mixture is read off the very base of the porcelain. Out there on the end means little to nothing
