Page 2 of 4 1 2 3 4
Re: Expensive 9 inch rears! [Re: Locomotion] #1771133
03/04/15 10:41 PM
03/04/15 10:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Yep, you're right, proved your point. Every Mopar in the world should have a Dana. Thread closed, problem solved, nothing to see here people, move along........LOL!!!!
Ford 9" has it's place and obviously it's quite popular in SS and the factory race cars, among others, for many reasons. I'm just trying to take the edge off of Quicktree who thinks that EVERY BRAND of race car in the world should have a Ford 9", even the average bracket racer!
LCOMOTION
UICKTREE
they do where have you been? 9"s outnumber the dana 100-1 at just about any race track
Re: Expensive 9 inch rears! [Re: Quicktree] #1771134
03/04/15 10:46 PM
03/04/15 10:46 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Chassis works "FAB 9" with a Strange case in my truck
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Expensive 9 inch rears! [Re: slammedR/T] #1771135
03/04/15 10:47 PM
03/04/15 10:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
come on, you could have had a junkyard dana
Re: Expensive 9 inch rears! [Re: Quicktree] #1771136
03/04/15 10:48 PM
03/04/15 10:48 PM
slammedR/T Offline
slammedR/T  Offline
I'm good
racemagnum
Re: Expensive 9 inch rears! [Re: slammedR/T] #1771137
03/04/15 10:51 PM
03/04/15 10:51 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I'm good
my son is taking over track prep at greencove. he was out there stripping the old rubber getting it ready.good thing you have that 9
Re: Expensive 9 inch rears! [Re: dvw] #1771138
03/04/15 10:59 PM
03/04/15 10:59 PM
Hilltown Pa
1967dartgt Offline OP
Hilltown Pa
I can see now these are much better than a junkyard Dana. And I like the ability to change the gear ratio at only $1000 a pop. Heck, I think I'll carry 2-3 to suit my needs. So for the initial investment of say roughly $1800 plus extra center sections ($3000) cause they're easy to swap I'll be all set, thanks.
Doug
Yes those junk yard rears with unknown mileage and if it was ever in a accident. This rear is all new fresh off a jig. But it's only your life your gambling with so no big deal if it locks up at 150 on the big end.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Expensive 9 inch rears! [Re: Quicktree] #1771139
03/04/15 11:00 PM
03/04/15 11:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It amazes me that this junk yard piece of crap can function.
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771140
03/04/15 11:01 PM
03/04/15 11:01 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Doug
you would probably have to push him to get to 150
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771141
03/04/15 11:15 PM
03/04/15 11:15 PM
Hilltown Pa
Hilltown Pa
So for 1590.00 you can have a brand new 9 inch rear. New axle tubes, new gears, new yoke 1350 billet, new spool, new axles, all new bearings and bolts.
Re: Expensive 9 inch rears! [Re: dvw] #1771142
03/04/15 11:17 PM
03/04/15 11:17 PM
Hilltown Pa
Hilltown Pa
That polished chrome cover come from junk yard? So what parts came from the yard in your rear?
Re: Expensive 9 inch rears! [Re: Quicktree] #1771143
03/04/15 11:26 PM
03/04/15 11:26 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Ok lets start over. Junkyard Dana, in this case, free. Narrowed by me, new strange spool, axles, bearings, Motive gear and Dr Diff yoke. Total cost just over $800. Obviously I didn't bolt it in from the junk yard. And your correct it would need a push to go 150, hasn't been past 148.
Doug
Re: Expensive 9 inch rears! [Re: Quicktree] #1771144
03/04/15 11:35 PM
03/04/15 11:35 PM
slammedR/T Offline
slammedR/T  Offline
I'm good
Heck bud that is awesome :thumbup I haven't been out there in awhile as it hurts to go watch running vehicles go down a track LOL
racemagnum
Re: Expensive 9 inch rears! [Re: slammedR/T] #1771145
03/05/15 12:09 AM
03/05/15 12:09 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
gong in my 73 chassis car
Re: Expensive 9 inch rears! [Re: dvw] #1771146
03/05/15 12:30 AM
03/05/15 12:30 AM
K
KOS Offline
KOS  Offline
K
Doug
Doug
Dana60 strongest rear per dollars spent... PERIOD
i got $1300 into mine with all aftermarket goodies ready to bolt in.
Re: Expensive 9 inch rears! [Re: 1967dartgt] #1771147
03/05/15 12:39 AM
03/05/15 12:39 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Make sure To get big Ford ends,and w a plate they sell you can use the same disc you already have.
Re: Expensive 9 inch rears! [Re: KOS] #1771148
03/05/15 02:01 AM
03/05/15 02:01 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
So much arrogance in this thread...
x2 on the junkyard D60, for mild street/strip it makes no sense to blow $3k+ on a rear when one can be pieced together for around $1k
Re: Expensive 9 inch rears! [Re: fishy340] #1771149
03/05/15 02:29 AM
03/05/15 02:29 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
After initial setup on my Dana I can change gears in a half hour or less. Never had to run pro gears either. We ran a ring gear that had a broken pinion with a pinion from a broken gear, and ran them together for one season till we came across a used set to 50 bucks. Dana is just strong, don't under estimate it. Unless you run heads up racing why do want to have extra gear sets ready is beyond me.
Re: Expensive 9 inch rears! [Re: cudaman1969] #1771150
03/05/15 02:41 AM
03/05/15 02:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not that I could care less what any one runs for a
rear end but I find it strange that the drag pack cars
run a 9"... I run a 8 3/4 and a 9" in my cars.. its
what I had to put in them
Re: Expensive 9 inch rears! [Re: cudaman1969] #1771151
03/05/15 03:00 AM
03/05/15 03:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your faster than ANYONE I've seen(if your doing it
right).. I helped 2 guys on drag week (1 chevy and
1 mopar.. 12 bolt and a dana) change gears laying
on the ground.. its not fun... and both took WELL
over 2 hours... but I'm slow I guess(I dont do it
for a living)
Re: Expensive 9 inch rears! [Re: MR_P_BODY] #1771152
03/05/15 07:50 AM
03/05/15 07:50 AM
Q
Quicktree Offline
Quicktree  Offline
Q
for a living)
I have to call BS on the less than half hour. maybe if you just slap them in there with out checking and setting them up.
Page 2 of 4 1 2 3 4
