70 RR- Back glass install #1771046
03/04/15 11:54 AM
03/04/15 11:54 AM
New Mexico
JMCFAN Online content OP
JMCFAN  Online Content OP
New Mexico
Should be ready to drop rear glass in this weekend. Tips/Tricks?
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR- Back glass install [Re: JMCFAN] #1771047
03/04/15 12:49 PM
03/04/15 12:49 PM
pa.
dan9 Offline
dan9  Offline
pa.
Get a helper and set the glass in before you put in the ribbon sealer. Once you get it centered put some masking tape on the glass and body to mark the center and how high it sets from the bottom. I use the 5/16 ribbon but the make 3/8 also. Make sure your reveal moulding clips are installed and in good shape. Line it up with your marks and you'll be good to go.
