Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: XV level II front suspension. Who is using it? [Re: cdoublejj] #1770402
03/22/15 01:45 AM
03/22/15 01:45 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You can talk about effectiveness until your blue in the face, I agree moving it up would help, getting it closer to the pinch weld, and help clear the distributor. Another thing is the effectiveness with the coilovers vs T-bars.
Mopar to the bone!!!
Re: XV level II front suspension. Who is using it? [Re: 72Swinger] #1770403
03/22/15 08:25 AM
03/22/15 08:25 AM
NY
X
XVracing Offline
XVracing  Offline
X
NY
There are a lot of constraints here also... The engine brace was design to fit a variety of engine, induction, and brake combinations. It was designed to fit big block, and 426 hemi cars and the main focus is of course the GenIII hemi's. Along with that is was made to clear the distributors of the big blocks and Hemi's, along with the piston AC compressors. It also clears the BB fresh air, air cleaner as well as the HEMI vacuum booster.
That's a lot of stuff to deal with!!!
And again, these were all tested on the rig and verified. So we can sit back in our chairs and say change this or change that, but everything has a cause and an effect and modeling everything the way they did, came up with the best overall solution.
If the chassis stiffness package wasn't so effective, people probably wouldn't be trying to copy it...
CR
Re: XV level II front suspension. Who is using it? [Re: XVracing] #1770404
03/22/15 12:03 PM
03/22/15 12:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CR
Not trying to turn this into a bashfest on XV, but we highly motivated to ensure an improvement is such.
Using cheater copycats to validate your engineering is a pisspoor option. At best they validate your reputation without confirming that rep is valid, just popular.
If we cared about popular we'd be in Chevys.
Don't be the exception.
Re: XV level II front suspension. Who is using it? [Re: Supercuda] #1770405
03/22/15 03:07 PM
03/22/15 03:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
When exactly did XV Motorsports release laser cut subframe connectors? I'm pretty sure years ago when I bought a pair, US Car Tool was the only source.
I know for a fact XV Motorsports copied my Mustang Cobra based front and rear disc brake kits.
Re: XV level II front suspension. Who is using it? [Re: Supercuda] #1770406
03/22/15 03:10 PM
03/22/15 03:10 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
IM not bashing either Chris, I am an A-body owner so what I think doesn't matter anyway. The Heims are probably fine in a coilover car but I know they are not IDEAL arresting TWIST with T-bars.
Re: XV level II front suspension. Who is using it? [Re: 72Swinger] #1770407
03/22/15 04:25 PM
03/22/15 04:25 PM
NY
X
XVracing Offline
XVracing  Offline
X
NY
And folks, this is how every one of these ends... People wonder why manufacturer's aren't more active in these forums...
If anybody wants any information or details, please PM, email, or call me at the shop...
CR
Re: XV level II front suspension. Who is using it? [Re: XVracing] #1770408
03/22/15 11:26 PM
03/22/15 11:26 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I understand that its easy to get feelings hurt, but we are supposed to be grown ups, nobody is perfect, everything can be made better, and if iI don't make a critical comment, some else or your competitor will, and good engineering design is not arm chair engineering, and most manufacturers leave because they find it easier to close their ears then open their eyes. Yes, this is a tough crowd, and running off any manufacturer helps no one, and is never mine nor I suspect anyone else'e intent. Making a better product is. In my case my suggestions require very little effort to implement other then maybe eating at the absolute worst case a little crow and agreeing a slight change makes for an improvement. I don't see the problem. Wanting all glory and no heat for a product is not realistic. We want you to succeed, if you are listening.
Re: XV level II front suspension. Who is using it? [Re: jcc] #1770409
03/23/15 12:10 AM
03/23/15 12:10 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yes, but some don't act like grown up. And just want to rudely impolitely nit pick and over scrutinize any ideas that are not their own.
And refuse to believe there are possibly two ways to get to the same place (maybe even three?).
Re: XV level II front suspension. Who is using it? [Re: XVracing] #1770410
03/23/15 02:58 AM
03/23/15 02:58 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
The video states 9800 is that of the unstiffened chassis, equal to a modern day sedan. The stated goal was 15000, equal to a modern day sports car.
Video 3, 1:20-1:45
That sounds about right, it's a ton of raw data, and I'm not sure if the actual numbers were ever published...
Thanks for finding that....
CR
are we talking torsional or beaming stiffness?
that piqued my interest so i asked the googles for a list for chassis stifness and found this one for torsional. Its in newton meters 9800ft/lbs*1.3558=13,286NM
http://www.germancarforum.com/threads/the-list-torsional-rigidity.12334/
if thats accurate, im somewhere between impressed and shocked with the E-body chassis
"so says the interwebs", it may be completely made up. IDK
Re: XV level II front suspension. Who is using it? [Re: Supercuda] #1770411
03/23/15 04:19 PM
03/23/15 04:19 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Is there any good before and after tests on these aftermarket suspensions?
By good I mean a couple of things. Third party, same rims and tires and if possible same brakes?
I have axcess to CarSim at work. If I could get enough information on the stock, XV, and Hotchkiss systems I could build a generic E body and simulate skidpad, slalom, general ride, braking, and some more free form dynamics. Body and tires would be constant. To be very precise it needs K and C data to account for bushing movement but for what we are doing here that shouldn't have an affect.
I need spring or wheel rates, sta bar rates, pickup points, etc. I have no way of getting that info other than a stock E body I have access too.
If Dan and Chris are interested PM me. More than agreeable to signing an NDA for the specs. I have no dog in this fight other than answering questions.
It would not happen over night, it takes a bit to build the model, paying work to do, yadda yadda.
Re: XV level II front suspension. Who is using it? [Re: Uhcoog1] #1770412
03/23/15 05:11 PM
03/23/15 05:11 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Offset UCA bushings.
I'm under the impression that A bodies with offset bushings will go further than B/E. I don't have any support for that, though.
That is amazing. I've done a lot of a-bodies and I've NEVER been able to get one anywhere close to that.
Alignments were done at Bumbera's- a race shop in Katy. I'll go to a new shop next time to see if the numbers are different.
As promised:
New numbers, new shop.
When 'maxed out' at this shop (front and rear cam bolts rolled for max camber), I was at:
LF: 10.1, -1.5
RF: 10.2, -2.5
Below is the compromise we ended up with. I am very pleased. I'll bring camber spacers with me to the track in the event I need more for the hoosiers.
LF: -2.3, 8.3
RF: -2.2, 8.6
Toe: 0.0
As a reminder for those who may not have seen the 'history':
My ride height is very low (factory bump stop height, more or less). I am really far into the caster/camber gain curve.
For my car and my ride height:
"Maxed out" caster for 1.2 camber was 6.9* caster
"Maxed out" caster for 1.5-1.6 camber was 7.1-7.3 caster
YMMV
I would 'like' to be able to get 8+* caster with -1.5 or less camber for street. Not possible. Aftermarket arms would be useful for this.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: XV level II front suspension. Who is using it? [Re: XVracing] #1770413
03/23/15 05:16 PM
03/23/15 05:16 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
CR
Thanks for keeping XV alive, Chris. I watched all the video's the other day and I am very appreciative of the research and work done by XV.
Re: XV level II front suspension. Who is using it? [Re: Uhcoog1] #1770414
03/23/15 06:45 PM
03/23/15 06:45 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
1/8" spacer between the balljoint/knuckle should help quite a bit. I use bronze bushings from the hardware store. They also sell 1/16" I didn't have any binding in the BJ. and still full thread engagement on the bolts.
Re: XV level II front suspension. Who is using it? [Re: Trojmn] #1770415
03/23/15 07:43 PM
03/23/15 07:43 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Between the lower ball joint and spindle? Those increase the camber, but don't do much, if anything, for caster. I have a set from Andy, and will be buying some thinner washers for potential track adjustments this weekend.
Re: XV level II front suspension. Who is using it? [Re: Uhcoog1] #1770416
03/23/15 07:52 PM
03/23/15 07:52 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
He is saying that if you can get your camber using spacers on the lower bolts, then you can use the upper arm eccentrics to max out caster instead of reducing the difference to gain camber.
Re: XV level II front suspension. Who is using it? [Re: TC@HP2] #1770417
03/23/15 08:19 PM
03/23/15 08:19 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Ah. Unfortunately it doesn't work that way for me. I can't go higher than about 7.0* caster without taking the camber above 1.5*. We've tried to no avail.
Re: XV level II front suspension. Who is using it? [Re: amxautox] #1770418
03/25/15 05:22 PM
03/25/15 05:22 PM
cataclysm80 Offline
cataclysm80  Offline
I thought XV was out of business.
Oh Man, Don't scare me like that!
They make some great stuff. I love the power window kit.
Tav
Re: XV level II front suspension. Who is using it? [Re: jcc] #1770419
03/25/15 05:39 PM
03/25/15 05:39 PM
cataclysm80 Offline
cataclysm80  Offline
The problem with the pictured solution is for one, where the brace connects to the firewall, I bet one can almost by hand bend the sheet metal, but it the brace was moved up only say 4"?, it would near a 90 degree bend and be magnitudes stiffer. Nobody sees this?
You might want to take a closer look at E body sheet metal.
Where that brace meets the firewall is very near to the 90 degree bend for the horizontal part of the firewall sometimes known as the rain pan. Not only is there a 90 degree bend located there, but it is also reinforced by a second piece of sheet metal called the cowl which is welded onto the firewall. The mounting plate for the brace overlaps this weld near the 90 degree bend.
Tav
Re: XV level II front suspension. Who is using it? [Re: Trojmn] #1770420
03/25/15 10:30 PM
03/25/15 10:30 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Why not use the SPC arms I sell? They can use the eccentrics AND the adjustable legs of the arm. I am going to try this and by the looks of it, I should be able to achieve 8.5 easily. Mine are at 4 now and the arms are not extended at all to do so.
Re: XV level II front suspension. Who is using it? [Re: BergmanAutoCraft] #1770421
03/25/15 10:49 PM
03/25/15 10:49 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Keep me posted as to how THAT works! I bought the SPC arms for a Charger and was wondering if it was necessary to use the eccentric bolts or if I could get it spec'd where I want it without them...
2 Demons...no, not my kids!
