BB Main studs -install finger tight? #1770225
03/03/15 04:11 PM
03/03/15 04:11 PM
Penna
70satelliteguy Offline OP
Penna
Is this what is best and why? I have always installed them tight with Allen wrench!
Mike
Re: BB Main studs -install finger tight? [Re: 70satelliteguy] #1770226
03/03/15 04:21 PM
03/03/15 04:21 PM
IL
knyech1 Offline
knyech1  Offline
IL
All you really need to do is tighten them by hand. And by hand I mean lightly with your fingers. Once you torque the nut to spec, it puts a clamp load on the head and puts a certain amount of tensile stress on the stud, which stretches the stud slightly (elastic deformation). In this state, the stud is "pulling" up against the threads, locking it in place. Make sure that you run a tap in the holes to make sure they are clean in order to attain proper thread engagement.
Also, USE THE THREAD LUBE THEY GIVE YOU or at least oil the threads. Some people think torque is torque and that is your indication that the fastener is serving its purpose. Torque is a measure of force required to overcome the friction between the threads. I have run some tests in the past on a Skidmore Wilhelm (which measures clamp load), where I took two bolts, one with thread lube and one dry, and torqued them down to the same value, and the bolt with the thread lube had a much higher clamping force than the dry one.
Ok has been given
Re: BB Main studs -install finger tight? [Re: knyech1] #1770227
03/03/15 04:43 PM
03/03/15 04:43 PM
Denison,Ia.
Cuda367 Offline
Cuda367  Offline
Denison,Ia.
I don't even like them finger tight. I install them finger tight then very slightly loosen. The idea behind this is tightening them can cause the stud to be force in a direction as the non threaded area tries to go into the threads. leaving them slightly loose lets them a line with bore in cap.
Re: BB Main studs -install finger tight? [Re: Cuda367] #1770228
03/03/15 08:31 PM
03/03/15 08:31 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Bingo!
