You would want a CB-743HN, which is a narrowed bearing. The X is for extra clearance, but there is no way of knowing whether or not you need that until you mic the crank and measure the rod bore with the bearing installed. At that point you would determine which size bearing to put in. Most aftermarket performance cranks will measure 2.199-2.1995 on the rod journals, but I dont know about the 440 Source stuff.If it measures 2.100 I'd be willing to bet you'll need an "x". If you dont have a way to measure both the crank and rod bore, take it to a machine shop. This ( bearing clearance) is not a place to make a mistake or assumption.
RIP Monte Smith
