Hey guys!
My spring project is to add multi point fuel injection to the 383 in my Super Bee.
There are no readily available EFI intakes for the B engines out there, so I am modifying an Edelbrock Torker single plane that I found.
This is a surprisingly time consuming task (nobody will mistake me for a machinist!), but I have some nice 90 degree holes in my intake runners (placed about 1" up the runner) that match my Edelbrock fuel rail.
So, what I need to know is... how deep into the intake port holes should the injector bungs be placed? When the bungs are final installed (all with the same height), do I want any part of the injector to actually protrude into the intake runner when installed into the bungs, or does the distance from the injector tip to the port even matter as long as the o-ring seals?
Thanks!
