Re: Lets see how you plumbed an oil accumulator with
[Re: Dragula]
#1768968
03/02/15 02:54 AM
03/02/15 02:54 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have no picture ,I'll try to explain The engine has a AndyF B/RB front plate. Starting with a remote oil filter pump cover up to a remote filter mounted on the front motor plate. The filter top has 4 ports, I used 2 of those. Coming from the pump into the filter, then out of the filter returning to a input tee at the pump. from that tee up to the accumulator. I have an electric valve on the accumulator that is actuated by the ignition switch. All plumbed with #8an fittings and hose. The accumulator is mounted on the cage front down tube. I felt that by running the oil straight back into the engine where the oil usually travels was better than plumbing it into the back of the block where the oil pressure sender was as that port is small.
[Re: rowin4]
#1768969
03/02/15 04:24 AM
03/02/15 04:24 AM
Posts: 4,648 aotearoa
rebel
aotearoa
[Re: gregsdart]
#1768972
03/02/15 09:20 PM
03/02/15 09:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
-10 lines from the oil pump cover to remote filter, extra port on the oil filter remote to accumulator. sorry, no picture.
Same way I did it.... as REBEL shows... worked great then I changed over to a dry sump and primed it
[Re: Dragula]
#1768974
03/03/15 12:22 AM
03/03/15 12:22 AM
Posts: 9,966 MI, usa
dvw
MI, usa
Mines way to simple. One #8 to the pump. Mounted on the engine plate. Sorry line is missing in the pic. Goes from accumulator to the plug on the Indy Max pump Just below the electrical connector at the bottom of the alternator. Doug
[Re: Dragula]
#1768975
03/03/15 01:38 AM
03/03/15 01:38 AM
Posts: 740 WA
JD Dart
WA
I'll tell you a story at Vegas the car set for months at Al's place went to start it fired accumulator good oil pressure then started car low oil light came on empty what was left of the accumulator fired it again low oil light came on and stayed on. Took the distributor out and primed it took 5 minutes with a drill motor almost gave up thinking were done. That's when I went to the check valve and remote filter before it feed into the back of the block. But this way what comes out of the accumulator is filtered no more pump cavitation. You don't need to run a remote filter I'd say without reservation if your not using the Milodon dual line pickup and feeding into the back of the block.
