Re: New 5 spd transmission available soon [Re: ScottSmith_Harms] #1768423
03/03/15 06:18 PM
03/03/15 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Scott, you're the one that brought up the subject of "hacking" not me. I simply stated that the subject trans doesn't offer anything that the Tremec doesn't already.
A Tremec TKO600 slid into my '56 Plymouth like it was made for it....not all of us limit our interests to A, B and E-bodies.
Re: New 5 spd transmission available soon [Re: John_Kunkel] #1768424
03/03/15 06:29 PM
03/03/15 06:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Not to with you John, just curious because I've never seen a 5 speed Tremec fit any B,E or A body (which Im sure is what that vast majority on Moparts own) without hacking.
*BTW, I agree, the McCloud looks pretty similar to a Tremec
Re: New 5 spd transmission available soon [Re: ScottSmith_Harms] #1768425
03/03/15 07:28 PM
03/03/15 07:28 PM
dogdays Offline
dogdays  Offline
And I took the comment to mean that if the Tremec required hacking to get it to fit, the other transmission required hacking as well.
It seems that the only surefire 5-speed replacement is the Passon, whatever its status is.
R.
Re: New 5 spd transmission available soon [Re: dogdays] #1768426
03/03/15 07:32 PM
03/03/15 07:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only downside to the Passon setup I can see it the wait.
Cost is inline with other setups, work required is much less. I guess only the impatient, the foolish or the name droppers need buy the others.
Don't be the exception.
Re: New 5 spd transmission available soon [Re: dogdays] #1768427
03/03/15 07:34 PM
03/03/15 07:34 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
As of now..
Still no product...
Only smoke & mirrors...
We need to see some actual product & installs....
Just my $0.02...
Re: New 5 spd transmission available soon [Re: Sinitro] #1768428
03/03/15 08:05 PM
03/03/15 08:05 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Ya 5 years ago when it was "availabe soon" I was interested. I see product is still not available.
Re: New 5 spd transmission available soon [Re: ScottSmith_Harms] #1768429
03/03/15 08:15 PM
03/03/15 08:15 PM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Really, because a TKO600 doesn't look anything like the McLeod to me.
Looking closely at the McLeod, they may be able to pull this off. It appears the front mounting plate is removable and the tail shaft is removable so only the gear cluster section is constant between all derivations. If that's the way they are tackling this, they may be able to make this work because, and I imagine this is the drawback for any trans manufacturing, is that you will need three distinct cases to cover Mopar applications, A/F, B, and E. By changing out the tail shaft and its associated shifter locations, they can make one case fit all lengths and shifter locations.
Re: New 5 spd transmission available soon [Re: TC@HP2] #1768430
03/03/15 08:17 PM
03/03/15 08:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why?
Chrysler had one case for all three, only the tail shaft and associated parts varied.
Re: New 5 spd transmission available soon [Re: TC@HP2] #1768431
03/03/15 08:22 PM
03/03/15 08:22 PM
Manitoba, Canada
Manitoba, Canada
For as small and stingy as the mopar market is, I highly doubt we will ever see different tail housing/shifter locations for various mopar models. All on the transmissions that's 1/2 a decade behind schedule from a big company like mcleod.
Re: New 5 spd transmission available soon [Re: astjp2] #1768432
03/03/15 10:11 PM
03/03/15 10:11 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
500ft/lbs is a pretty low rating for a manual transmission designed for classic muscle cars. Heck, my mild 440 has 530ft/lbs. I can see durability being a potentially serious issue for a lot of guys.
I think this is meant for the small block guys who are happy with only 500 ftlbs of torque. Tim
Even my stock stroke 340 made 455 lb-ft. Just plain not enough headroom on this trans. Anything made for these cars shouldn't be weaker than a 23 spline A833.
If the A833 ever comes out, I'm getting the Passon 5-speed. Hoping that list gets shorter in the coming months.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: New 5 spd transmission available soon [Re: Supercuda] #1768433
03/04/15 11:58 AM
03/04/15 11:58 AM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Why?
Excuse me, three tail shafts.
Valid point. So, since all new transmissions are rated by lb ft capacity, where would the venerable A833 fall in this range? It certainly is a strong trans, but by no means is bulletproof. While a slick shifted crash box may have lasted for a dozen passes at the dragstrip behind a high output Hemi in the hands of Mr. Sox, I can recall a few DNFs from the 1970 Trans Am season for gearbox problems with engines that had much lower specific output than the Factory Experimental, Modified Production, and fledgling Pro Stock class.
Re: New 5 spd transmission available soon [Re: TC@HP2] #1768434
03/04/15 08:17 PM
03/04/15 08:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
See now that's where putting a torque capacity rating on a transmission is just a marketing tool. You could put a 23 spline box behind a 1000 HP HEMI with 800 FT.LBS. of torque as long as you put a slipper clutch in between them If you put that Mcleod box in a 3600 pound B-body with a 14" slick and a Mcleod Street-Twin it will fail If they rated a transmission for "intended usage" you would see a much different price tag on them. They should include the proper clutch package with a transmission for the weight of the car and the power of the engine
I never hurt an 18 spline HEMI box until I put a Mcleod dual disc clutch in the car that didn't slip.Then I started breaking stuff and I might be pushing 600 ft. of torque
The shifter position is still gonna require extensive mods to the torsion bar crossmember
Gus
64 Plymouth Savoy
Dana 60
Re: New 5 spd transmission available soon [Re: fourgearsavoy] #1768435
03/04/15 09:54 PM
03/04/15 09:54 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The Mopar version is offset.
Like I said, lets wait and see when it is released. Options are nice.
"I think its got a hemi"
