What kind or rear diff oil for 8 3/4 clutch type SG #1768327
03/01/15 03:11 PM
03/01/15 03:11 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What brand and type of rear gear oil do you recommend for 8 3/4 rear with clutch type Sure Grip. My rear housing gets pretty hot, and am looking for an oil that might make it run a little cooler. Thanks.
Re: What kind or rear diff oil for 8 3/4 clutch type SG [Re: ragtop] #1768328
03/01/15 03:26 PM
03/01/15 03:26 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think doc diff recommends 85w/140w conventional with a bottle of ford FM. That said I have Torco RGO 85/140 ready to go in this spring.
Re: What kind or rear diff oil for 8 3/4 clutch type SG [Re: ragtop] #1768329
03/01/15 03:30 PM
03/01/15 03:30 PM
Kirkland, Washington
Pacnorthcuda Offline
IF it's overheating then a different fluid ain't gonna cure that. IF (big IF) it's overheating then something is too tight.
I run conventional 75/90 with the Ford friction modifier in mine.
Re: What kind or rear diff oil for 8 3/4 clutch type SG [Re: Pacnorthcuda] #1768330
03/01/15 03:54 PM
03/01/15 03:54 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
How hot to the touch of the rear housing is considered to hot? Thanks.
Re: What kind or rear diff oil for 8 3/4 clutch type SG [Re: ragtop] #1768331
03/01/15 03:59 PM
03/01/15 03:59 PM
I am not sure, but I think around 150 is pretty normal. Doc Diff may chime in with the answer.
Re: What kind or rear diff oil for 8 3/4 clutch type SG [Re: ragtop] #1768332
03/01/15 04:31 PM
03/01/15 04:31 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
All rears run hot enough to almost burn your hand. In other words, it is very uncomfortable to the touch.
