'70 Superbee underhood wiring details #176624
12/27/08 08:57 PM
12/27/08 08:57 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Hey guys, I'm trying to put together what I did not take apart as my car was a 'basket' when I brought it home. I'm going to maybe run several questions into this thread as I discover what it is I need to know regarding underhood wiring...and I'm no expert in this area.
For starters, I have a single horn. Should there be two? I have what I believe is a horn relay, has three prongs on it. Where does this item mount? Any pictures of the horn(s) and relay and how they are situated is much appreciated.
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176625
12/27/08 09:33 PM
12/27/08 09:33 PM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Jeff,
The horn relay is mounted inside the car along the lower horizontal edge of the dash frame.
You should have two horns, both are mounted on passenger side core support. I'm posting on my phone right now, but if no one chimes in with photos, I'll post some Sunday or Monday.
Re: '70 Superbee underhood wiring details [Re: Paul] #176626
12/27/08 11:33 PM
12/27/08 11:33 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
ok here ya go...from my 70 383 4 bbl Coronet
first from the alternator over to the right side inner fender
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176627
12/27/08 11:34 PM
12/27/08 11:34 PM
Va. Beach, Va
Va. Beach, Va
next at the inner fender under the washer tank
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176628
12/27/08 11:35 PM
12/27/08 11:35 PM
Va. Beach, Va
Va. Beach, Va
at the horns
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176629
12/27/08 11:36 PM
12/27/08 11:36 PM
Va. Beach, Va
Va. Beach, Va
Good view of top horn
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176630
12/27/08 11:37 PM
12/27/08 11:37 PM
Va. Beach, Va
Va. Beach, Va
and the bottom horn
wires are green with tracer
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176631
12/27/08 11:40 PM
12/27/08 11:40 PM
Va. Beach, Va
Va. Beach, Va
I just did the engine and forward light harnesses on the car last weekend. I will see if I can grab a pic of the relay under the dash
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176632
12/27/08 11:50 PM
12/27/08 11:50 PM
Va. Beach, Va
Va. Beach, Va
Ok here ya go. Not a good pic but it should work. You can see the parking brake handle in the left lower corner for orientation. the shiny object next to the oval hole is the mounting screw and you can see the gray plug as well as the relay thru the oval hole
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176633
12/27/08 11:52 PM
12/27/08 11:52 PM
Va. Beach, Va
Va. Beach, Va
And here is the relay. the mounting screw is at the bottom and you can see all three wires pretty decent here.
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176634
12/28/08 02:38 AM
12/28/08 02:38 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Hotdog, that's what I need. For whatever reason, the horn relay was not plugged in and two of the wires were jumped. That's one of the only butcher jobs I've seen so far on my original wiring harness.
Thanks again.
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176635
12/28/08 03:03 AM
12/28/08 03:03 AM
Va. Beach, Va
Va. Beach, Va
I have seen them do that when the horn button in the column fails and they wire in an under dash button instead.
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176636
12/28/08 03:24 AM
12/28/08 03:24 AM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Well since I didn't get a steering column with the car when I brought it home I'm hopefull that the horn button in the one I got is one that works. We'll be finding out when I get some of these loose ends buttoned up and put a battery in the car.
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176637
12/28/08 12:51 PM
12/28/08 12:51 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176638
12/28/08 01:21 PM
12/28/08 01:21 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Here's another problem, my regulator is an earlier style which I know isn't right. I got the '70 only bracket that mounts to the firewall, now I need a regulator. I'm hunting around online and all I see are the ones with the funky triangular 3 prong connector. I don't think those are the right thing? What do I need and where can I get it?
Here's a pic of what's at Napa or Autozone typical down below;
Here's a pic of Lonnie's (Hakkarcharger) car which I'm using for reference;
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176639
12/28/08 01:30 PM
12/28/08 01:30 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Just for fun here's an overall shot of Lonnie's car, nicely optioned 4 speed COUPE!
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176640
12/28/08 05:27 PM
12/28/08 05:27 PM
Houston Texas
Houston Texas
Is that ev2 or fe5? I also have a 4 speed '70 coupe (in fe5), but it is very low on options (none). Between mine and that one, we make up two of 1,336 4 speeds made!
Re: '70 Superbee underhood wiring details [Re: PAINT IT BLACK] #176641
12/28/08 07:54 PM
12/28/08 07:54 PM
Kingsburg Calif.
Quikshft Offline OP
Quikshft  Offline OP
Kingsburg Calif.
Lonnie's car is EV2 like mine, it's almost like looking at my car when it's done except I'll have a gatorgrain top.
Re: '70 Superbee underhood wiring details [Re: Quikshft] #176642
12/28/08 10:56 PM
12/28/08 10:56 PM
Va. Beach, Va
Va. Beach, Va
I just got one of the Mopar repops. I think it was 25 bucks and yep that is the connector. Oh and if you get the Mopar black one take the paint off the back for a good ground...dont ask me how I know this
Re: '70 Superbee underhood wiring details [Re: 69superbee383] #176643
12/28/08 11:01 PM
12/28/08 11:01 PM
Va. Beach, Va
Va. Beach, Va
Here is an odd ball for you. Coronet 440 post coupe with the 383 4 bbl and 3 speed manual.
