Head Gasket: Mr Gasket 1121G vs Fel Pro 8553PT #1765540
02/28/15 09:56 PM
02/28/15 09:56 PM
houston, tx
d100clubcab Offline OP
houston, tx
On a BONE stock 1974 360 would it make much difference between the .028 quench Mr Gasket or the .054 Fel Pro?
Wondering if I should wait a few days for the Mr Gasket to come in the mail or if I should run to the 24hrs AutoZone and pick up the FelPros and wrap this job up?
I know the Mr Gaskets give more compression but not sure how much of a difference it will make on such a below the deck piston anyway
some pics of the block and head (drivers side)
https://lh5.googleusercontent.com/-sz4m_ExW1GM/VPJTUxqj4hI/AAAAAAAABsg/UaEBTrdGAK8/s640/IMG_0183.JPG
https://lh4.googleusercontent.com/-ykrRGARZzP8/VPJTXvF7yqI/AAAAAAAABs0/HFZJ7zytZMk/s640/IMG_0186.JPG
https://lh5.googleusercontent.com/-C_JrPHMRRg0/VPJTYCJqbhI/AAAAAAAABs8/O9M9ecMIKfE/s640/IMG_0188.JPG
https://lh6.googleusercontent.com/-5GA8fNfpWOc/VPJTZYfSvOI/AAAAAAAABtE/-o0tt2lrGNQ/s640/IMG_0189.JPG
Re: Head Gasket: Mr Gasket 1121G vs Fel Pro 8553PT [Re: d100clubcab] #1765541
03/01/15 12:37 AM
03/01/15 12:37 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://www.uempistons.com/index.php?mai...b07af18eafa2003
using that calculator...and using estimated numbers like 70 cc head volume and only changing the head gasket thickness....I got 1/2 point change in compression .
Tony
70 AARCuda Vitamin C
Re: Head Gasket: Mr Gasket 1121G vs Fel Pro 8553PT [Re: 70AARcuda] #1765542
03/01/15 01:38 AM
03/01/15 01:38 AM
a half point ain't earth shattering but is something & the wait would give you time to have the heads milled (I saw the pics ) for even more gain. EDIT adv the cam 4 deg while you are at it then dial in the dist subsystems. You'll feel it
