Re: Backcut intake vavles
[Re: bracketcharger]
#1765109
02/28/15 04:35 PM
02/28/15 04:35 PM
Posts: 429 Washington
skrews
Washington
I usually bring the back cut to within .015 to .020 of the valve seat. I usually use a 33 degree angle. See pic.
#1765112
03/01/15 04:43 PM
03/01/15 04:43 PM
Posts: 133 Winter Park, Florida
classracer
The 452 intake port approaches the seat at a lower angle as compared to a 906 casting. I usually use back cut angles between 27 and 30 degrees on a 452 intake valve. Unless you have a way to see what your port likes, I would stick with a 30 degree back cut. If the 30 degree back cut gets to wide, sometimes I will narrow it with a second back cut angle. I do not use any back cuts on the exhaust valves.
70 Challenger A/SA 2441
