Best way to remove stripes on a car? #176497
12/27/08 06:48 PM
12/27/08 06:48 PM
Colorado
CuriousYella70 Offline OP
Colorado
I've got a few lower rocker panel stripes on my 07 Mustang that i'm looking to remove. I'm replacing them with matte black and have heard to take a blow dryer, heat them up and they should peel right off?
Any tips, suggestions?
Re: Best way to remove stripes on a car? [Re: CuriousYella70] #176498
12/27/08 07:50 PM
12/27/08 07:50 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Heat gun or blow dryer should do the trick.
Re: Best way to remove stripes on a car? [Re: Neil] #176499
12/27/08 09:23 PM
12/27/08 09:23 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Our body shop has some kind of rubber pad they put on a hi-speed air drill. Rubs the strip off but not the paint.
Re: Best way to remove stripes on a car? [Re: CuriousYella70] #176500
12/27/08 10:30 PM
12/27/08 10:30 PM
Jacksonville Florida
elitecustombody Offline
when a car is this fresh, heat gun will do the trick,just start peeling at one end with your nail and keep ging till all are off, but if they are stubborn,you'd have to get the
you can pick one up at any autobody paint supply store,just use it at low speed
