Fuel return line in fuel cell
#1764759
02/27/15 11:41 PM
02/27/15 11:41 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I got a new aluminum fuel cell to replace my crappy plastic cell. I was going to use a fuel return tube kit from JBRC that will put a fule line from the top fitting on the cell down to the bottom of the cell. But couldn't I just weld in a return fitting 1" from the tank floor and away from the pump inlet in like a front corner section of the fuel cell? Also I don't run foam in my cells anymore after I had a motor get killed from foam plugging the fuel filter.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Fuel return line in fuel cell
[Re: MR_P_BODY]
#1764761
02/27/15 11:52 PM
02/27/15 11:52 PM
slammedR/T
Sure ya can.. it will do the same thing.. just dump the fuel in the fuel.. not in the air space EDIT Just dont direct the fuel towards the pump... I try to spin the return off the walls
Yeah I was trying to explain it best I could, I geuss I should say on the fuel cell "side wall and back wall corners" if that makes more sense
[Re: slammedR/T]
#1764762
02/27/15 11:57 PM
02/27/15 11:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your OK
