318 polyshere #1764139
02/27/15 03:07 AM
02/27/15 03:07 AM
HAMILTON OHIO
roadrunnerandgtx Offline OP
super gas
super gas
HAMILTON OHIO
i have a question of will the distributor from a LA smallblock or a B block fit in a 318 poly? i want to run an electronic dizzy in my poly ON THE CHEAP
Re: 318 polyshere [Re: roadrunnerandgtx] #1764140
02/27/15 03:36 AM
02/27/15 03:36 AM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
hi
la small block will work.
Re: 318 polyshere [Re: calrobb2000] #1764141
02/27/15 03:41 AM
02/27/15 03:41 AM
dogdays Offline
dogdays  Offline
You can swap from one to the other and back, same with the timing set, oil pump and intermediate gear/shaft.
R.
Re: 318 polyshere [Re: dogdays] #1764142
02/27/15 08:08 PM
02/27/15 08:08 PM
HAMILTON OHIO
super gas
super gas
HAMILTON OHIO
very good to know thanks for the info
Re: 318 polysphere [Re: roadrunnerandgtx] #1764143
02/27/15 08:32 PM
02/27/15 08:32 PM
dogdays Offline
dogdays  Offline
If you have other questions PM me and I'll probably have an answer for you. I have run one for 20+ years.
R.
Re: 318 polysphere [Re: dogdays] #1764144
02/28/15 12:38 AM
02/28/15 12:38 AM
HAMILTON OHIO
super gas
super gas
HAMILTON OHIO
ok thank you much appreciate it
