new motor in - no start #176354
12/27/08 04:18 PM
12/27/08 04:18 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
Well after an all niter, I finally got my 400 in and ready, but I can't seem to get any juice to crank it. Everything else works, but the start circuit. I have a diagram, and it seems the neutral / safe / back up light circuit is dead.
Checked my harness and it seems everything is in place. Any ideas. Ignition switch, starter relay etc.
All of this worked before, too,
(86 truck used to be 318, now 400, 727 4wd )
Re: new motor in - no start [Re: 67MIke] #176355
12/27/08 04:22 PM
12/27/08 04:22 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
the first check would be to determine if the starter relay is getting juice when the key is in START. If yes, is the starter/solenoid getting juice under the same condition (from the starter relay)?
Re: new motor in - no start [Re: Pacnorthcuda] #176356
12/27/08 04:50 PM
12/27/08 04:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried moving the shifter while holding the key in the start position?
Re: new motor in - no start [Re: Pacnorthcuda] #176357
12/27/08 04:50 PM
12/27/08 04:50 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
nope nada on both
Re: new motor in - no start [Re: 67MIke] #176358
12/27/08 05:13 PM
12/27/08 05:13 PM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
yes, I wiggled cussed talked sweet you know the whole routine
Re: new motor in - no start [Re: 67MIke] #176359
12/27/08 08:40 PM
12/27/08 08:40 PM
I'd jump 12V to the "ign" terminal on the starter relay & if it cranks I'd trace it back to the ignition switch & find the "open". if no crank I'd ground the neutral safety switch terminal on the starter relay & turn key to "start" & if it cranks I'd trace that wire back to the trans & see why it's not grounding or just permanently ground it there at the starter relay being aware that the eng will now start & the vehicle will move if you start it in gear.
Re: new motor in - no start [Re: RapidRobert] #176360
12/28/08 12:38 AM
12/28/08 12:38 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
not to sound dumb, but would you explain how to ground the neutral switch. thanks - mike
Re: new motor in - no start [Re: 67MIke] #176361
12/28/08 12:53 AM
12/28/08 12:53 AM
We are all at different levels & I am regularly awed by the skill level/knowledge of the guys here & I learn more every day. There will be one terminal on the nss with a wire that goes back to the side of the trans. You would jump from this male terminal on the nss itself several inches to the base mounting bolt on the nss effectively permanently grounding it. When it's functioning, putting the trans in N or P grounds this wire at the other end at the trans, you're just doing the same thing(& permanently)upstream at the nss which is why it would now start in any gear as the trans is no longer controlling the grounding. EDIT those later nss's have way more connections than the 70's basic 4 terminal ones so ID them carefully.
Re: new motor in - no start [Re: RapidRobert] #176362
12/28/08 02:55 AM
12/28/08 02:55 AM
Hartselle AL
67MIke Offline OP
67MIke  Offline OP
Hartselle AL
thanks - I hope this will fix it - Mike
